Tip & How-To about Pool & Spa
Three tips for a cleaner pool
Having a pool at home can seem like a really awesome thing, but if its not cared for properly it can turn into a nuisance. There are a few small things that you can do on a weekly basis that will keep your pool clean and fun to play in. But keeping it clean can be very time consuming and physically taxing.
In movies you always see the pool boy skimming the top of the water of a pool with a long pole with a net on the end. What this does is it catches all the leaves and other stuff floating in the water. You will want to do this fairly often because when you leave stuff floating in the pool they will sink and then become close to impossible to get out and wreak havoc on your circulation system.
In addition to build up of leaves or branches from trees around the pool there will also be build up of chemicals that will make the water not be clear. To get rid of the chemical build up you are going to want to vacuum the pool. Whenever you vacuum make sure that your check the filters and clean them if you have to, for a clean pool you should vacuum once a week.
Once you have skimmed and vacuumed you are almost done! To make sure that you don't get algae build up you want to scrub the sides and floor of the pool. What you use to scrub the pool is dependent on what your pool is made out of. If the walls are plaster lined concrete you will want to use a stiff brush while for fiberglass you will want to use a softer brush so you don't ruin the walls.
Pool & Spa Logo
1989 toyota celica
Just the other day, I finally received the answer to this problem with my '06 Rainier CXL. The front gear pack (in mine) needs to be replaced. Vehicle is driving AWD, all the time. Expensive repair- $1600. Mine has 93+K miles, the engine is in awesome condition. To repair or not to repair... that is my struggle.
Jul 18, 2013 | Cars & Trucks
keeps tipping over
With these automatic pool cleaners, this is often a problem with the treads or having air in the head. Make sure that your treads are not worn and are getting proper traction. If they are worn, you might need to replace. To rid the air, try turning the Aquabot upside down and submerse in the pool for a few minutes. This should force the air out.
Jul 12, 2009 | Aquabot In - Ground Robotic Pool Cleaner
Bought a new home with pool which has the Hayward Pro series sand filter pump but have no instructions for the care and pool maintenance or the filter maintenance.
Need some more info on the Sand filter. I can help you out. With the rest. Is that the pic of the filter you have. If it is then its a top mount. Depending on the debri that comes into pool, you will back wash 1-2 times a week. After back washing you will turn to rinse and let it run for awhile (of course each time you turn the handle make sure the pump is OFF. Set, then turn on.) then back to filter.. Any Q's just hit me up buddy..
Mar 03, 2009 | Hayward SAND FILTER, PRO SERIES
after about 5 min my system turns itself off
hi the problem your having could be one of a couple of things the first to check is that all the speaker wires a fitted correctly and not come out of socket as a speaker wire shorting could give you the problem your having.
The second and most likely problem is going to be a problem with the amp part of the circuit board usually a blown resistor but in your case as the unit comes on for few minutes then the chances are its just a solder joint failing on the board this causing the unit to trip out as a safety measure to stop it setting on fire.
Check the sub woofer cable is fitted properly as this is the usuall problem with you make and model let me know when you have checked all of this ok
Feb 25, 2008 | Panasonic sa-ht800V Home Theater Audio...
617 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
