Tip & How-To about Mintek MDP-1770 Portable DVD Player
Regional code change for MDP-1770 Portable DVD Player
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
Mintek MDP-1770 Portable DVD Player Logo
remove lamp cover from backup lamp assembly 2005 impala
Did you check the fuse , relay ? Backup Lamps
The B/U LAMP fuse in the RH I/P fuse block supplies battery positive voltage to the switch terminal of the backup lamps relay. The DIC/RKE fuse supplies battery positive voltage to the backup lamps relay coil terminal. When you place the gear selector lever in the REVERSE position, the powertrain control module (PCM) sends a class 2 message to the body control module (BCM). When these conditions occur, the BCM energizes the reverse lamp relay control circuit, closing the switch contacts, the current flows from the reverse lamp relay switch to the backup lamps. The backup lamps are grounded at G302.
Open the rear compartment. trunk lid
Remove the wing nuts from the studs on the rear compartment lid applique.
Remove the rear compartment lid applique from the rear compartment lid.
Remove the backup lamp sockets from the rear compartment lid applique, turning counterclockwise.
Remove the backup lamp bulbs from the sockets.
Sep 08, 2017 | Cars & Trucks
do I have to change my license plate assembly since my bulb is out on my 2004 Cadillac cts 3.6l v6
no just change the bulb .
Remove the rear compartment lid applique. Refer to Rear Compartment Lid Applique Replacement in Body Rear End
1.Remove the rear compartment lid trim. Refer to Rear Compartment Lid Inner Panel Trim Replacement .
Remove the fastener securing the rear compartment pull down strap to the rear compartment lid.
Remove the rear compartment pull down stap.
Remove the fastener securing the rear compartment release handle escutcheon.
Remove the rear compartment release handle escutcheon.
Remove the push-in retainers securing the rear compartment lid trim to the rear compartment lid.
Remove the rear compartment lid trim from the compartment lid.
Disconnect the rear compartment lid applique electrical connector (4).
Remove the fasteners that retain the rear compartment lid applique (1) to the rear compartment lid (2).
Remove the rear compartment lid applique (1) from the rear compartment lid (2).
Remove the rear compartment lid applique electrical harness pass through (3) from the rear compartment lid (2).
Remove the license lamp socket from the rear compartment lid applique by turning it counter clockwise.
Remove the license lamp bulb from the socket if replacing.
Remove the license lamp from the rear compartment lid applique by lifting the retaining tabs and sliding the lamp away from the applique.
Jan 20, 2017 | 2004 Cadillac CTS Sedan
can open my trunk doesn't work with remote or from inside of glove compartment thanks 2005 ssr chevorlet
The rear compartment lid can be opened by operating the rear compartment lid release switch, located on the instrument panel, or by using the manual release located on the rear compartment lid. Battery voltage is supplied to the rear compartment lid release relay through the Main Power fuse. The roof and door module (RDM) receives the rear compartment lid release request via the rear compartment lid release switch signal circuit. The RDM grounds the rear compartment lid release relay coil when a release input is received through the instrument panel (I/P) switch. Grounding the coil causes the rear compartment lid release relay to energize, providing power to the rear compartment lid latch assembly through the rear compartment lid release actuator supply voltage circuit.
As an alternate method of operating the rear compartment, an emergency release handle is accessible from within the rear compartment. When the handle is slightly pulled, it will provide a ground for the bed cover release relay which will cause the actuator to operate and open the rear compartment lid. If the handle is pulled further, it will mechanically open the lid, so even if the battery is discharged or there is an electrical concern, the emergency release handle will mechanically open the lid.
Jan 01, 2017 | Cars & Trucks
Locked out of trunk 2000 cadillac eldorado release button not working i removed lock on trunk still cant get in trunk
Pressing the rear compartment lid release switch provides an input signal to the instrument cluster. The instrument cluster sends a Class 2 serial data message to the body control module (PZM). The PZM grounds connector C6 of the rear compartment lid release solenoid through CKT 1344 (LT BLU) if the following conditions are present:
The transaxle is in the PARK position.
The valet lockout switch is closed.
Power is supplied through the following components to the now-grounded CKT 1344 (LT BLU):
The RADIO/PHONE fuse
CKT 40 (ORN)
The coil of the rear compartment lid release relay
The relay coil energizes and closes the relay contacts.
Power is supplied from the CONVENIENCE fuse through the following components:
CKT 2040 (ORN)
The now-closed relay contacts
CKT 56 (BLK/WHT)
The rear compartment lid release solenoid
The solenoid energizes and the rear compartment lid latch assembly releases the rear compartment lid.
Did you perform the rear compartment lid release system check?
Go to Rear Compartment Lid Release System Check
  1. Place the transaxle in the PARK position.
  2. Turn the valet switch OFF.
  3. Connect the scan tool to the data link connector (DLC).
  4. Turn the valet lockout OFF.
  5. Press the rear compartment release switch.
Does the body control module (PZM) command the rear compartment lid release ON?
Go to Step 3
Go to Step 7
  1. Disconnect the rear compartment lid release relay.
  2. Connect a test lamp between terminal D4 and ground, and terminal D6 to ground.
Does the test lamp light at both terminals?
Go to Step 4
Go to Step 14
  1. Connect the test lamp between terminal D4 and terminal C6.
  2. Press the rear compartment lid release switch.
Does the test lamp light?
Go to Step 5
Go to Step 15
5
Connect a fused jumper between terminal D6 and terminal C4.
Does the rear compartment lid open?
Go to Step 6
Go to Step 16
6
Replace the rear compartment lid release relay.
Does the rear compartment lid release operate properly?
Go to Step 7
If you don't know what your dealing with there is no way you can fix it . I suggest you take it to a qualified ASE certified repair shop or the dealer !
Aug 24, 2015 | Cadillac Cars & Trucks
cd sony 815 does not play cd
If you mean the Sony Model # ICF-CD815. A.K.A. Dream Machine
you should check the user manual, for troubleshooting instructions:
https://docs.sony.com/release/ICFCD815.pdf
from the manual:
The CD player does not operate.
  • Did you close the CD lid?
  • Did you place the disc correctly?
  • The disk should be placed with the labeled side up.
  • Dusty or defective disc-Clean the disc with an optional cleaning cloth. Wipe the disc from the center out
  • Take out the CD and leave the CD compartment open for about an hour to remove moisture condensation.
It seems to be a top loader system, so a few checks are in order:
  • Check that the disc spins (Insert CD, try to play and open the tray) Be careful, the disc might fly out of the tray!
  • Clean the CD drive lens with a cotton bud and some optical cleaner (camera shops and radio repair shops/techs should have a suitable liquid)
If the unit seems totally broken, take it to a tech or recycle it at a waste electronics depot and get a new one.
Apr 29, 2014 | Sony Under The Cabinet 3 Disc Cd/fm/am...
861 people viewed this tip
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
