Tip & How-To about Home
How to clean out your stovetop kettle
I've been using the same kettle on my stove for about a year and I hadn't cleaned it even once until last week.
A while ago I started noticing these weird white chucks that would come out with the water but I just figured that it was because I get a lot of use of out my kettle.
It turns out that the white chunks are actually limescale.
I did some research on it and thankfully limescale is not harmful to ingest. However, it's pretty gross to look at and I certainly wouldn't want to serve a cup of tea to a guest that is filled with strange white flakes.
So I figured out how to clean my kettle with stuff I have at home.
All you need is some regular cooking vinegar to do the descaling for you.
There is no need to buy expensive chemicals that you wouldn't feel safe using on a cooking product anyway.
Start by rinsing out your kettle with warm water.
Then, fill half of it with water and the other half with vinegar.
Place it on your stove and let it come to a rolling boil.
Then, just leave it there over night.
When you wake up in the morning, dump out the water and vinegar solution.
Take a long scrubbing brush and scrub the inside of the kettle to remove whatever limescale is left.
If there is still some caked on, you can repeat the steps over again.
If your kettle is clear of the grime, simply rinse out a number of times with soap to get rid of the vinegar taste/smell.
Voila! Your stovetop kettle is clean and no more unidentified chunks in your tea!
Home Logo
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Jul 22, 2013 | Poulan Garden
2000 Pontiac Grand Prix GT, front end shakes at 35-40mph?
You have worn front end parts or the tires have a separated cord in them.
Feb 28, 2017 | 2000 Pontiac Grand Prix GT
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Feb 18, 2012 | Chef's Choice 677 Cordless Electric Kettle
854 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
