Tip & How-To about Health & Beauty
Tips for Waxing - My Guide to Home Hair Removal
Not everybody has the money to spend going to a beauty salon for all their home hair removal needs. For some people it's also just not that comfortable and they feel shy about it.
Whatever the reason, waxing at home is a good option for longer term hair removal, but it takes a bit more planning and knowledge than simply taking a razor into the shower with you.
Check out my tips below for successful home hair removal.
Here are some of my don'ts:
1. Don't wax just after you've been sunbathing or exposed to any other form of excessive heat.
2. Don't go into a bath, hot tub or any other heated water place for a few hours after you've waxed as your skin can get really sore and the pores are more likely to get exposed to bacteria.
3. Don't wax if you are suffering from any kind of allergies or skin condition. Waxing is a super irritant to the skin and you'll only make it worse.
4. Don't start waxing and half way through read the instructions. Make sure you read them BEFORE you get started.
5. Be careful not to burn yourself. Test the temperature of the wax using the inside of your wrist NOT your leg!
Some do's for waxing:
1. Make sure you pull the wax strip off in the right direction. You smooth the wax strip down in the direction of the hair growth and then pull off the strip in the other direction.
2. Pull the wax strip off in one very quick motion. You should make sure that your movement to remove the wax strip is fast as doing it slowly will not only hurt more but also be ineffective.
3.Once you've waxed an area - don't go back to it even if you've missed a bit as this can really damage the skin and cause friction burns and bruising.
4. Use tweezers to remove any stray hairs that didn't come out with the waxing.
My final advice is that you should start with waxing just your legs and see how it goes. Waxing bikini and under arm areas is even more painful and takes a lot of skill. So start with your legs and if you're confident move on and if not, you can always go to a salon for that.
Good Luck
Health & Beauty Logo
Should I go to the salon or dye my hair at home? Any recommendation regarding Brisbane Salons?
I think salon is better option for getting a nice hair dyed and for that i recommend you to check the services of Beauty salon Brisbane
Oct 21, 2013 | Sexy Hair Health & Beauty
How often should you have your hair cut? My hair salon said I should be coming in once a month but that sounds ridiculous. Are they just trying to get more money out of me?
I don't know about once a month - that sounds a bit too often, but it really is recommended to cut your hair every 6 weeks. This cuts off any split ends and damaged hair and generally gives a more healthy and robust look to your hair
Feb 14, 2013 | Health & Beauty
diagram serpentine belt alternator 93 lexus es300
1. This is not a question, it is a tip. Please post it under Tips.
2. Why do you have waxing tips titled "Diagram serpentine belt alternator 93 lexus es300" ?
Feb 27, 2017 | Health & Beauty
695 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
