Tip & How-To about Water Sport
Not all ropes are created equally
Choosing the wrong type of rope for the purpose you are going to be using it for can result in injury and / or broken property. It may seem to you that some ropes are a little thicker than others, or that some feel stronger than some others. It is very important that you know what you are going to be using your rope for and doing a little research before you walk into a hardware store and blindly buy just any rope.
For water skiing the ropes that come with the ski isn't made to handle shock loading, this is when the rope goes completely slack and then get taught very quickly. This can lead to injury should the rope snap. This is why many water skiers and water tubers go out to buy replacement ropes.
There are many different strengths of towing ropes and cables, the recommended strengths for tubing are 3,350 lb. break strength, 4,100 lb. break strength and 6,000 lb. break strength. A regular rope that you might pick up at a hardware store might only have a break strength of 1,350 lb. which is not strong enough. Also when you buy the rope specially made it will have the knots already in the rope so you don't have to tie them yourself. When you do tie the knots yourself it tends to reduce the strength of the rope.
Its always better to be safe than sorry. When it comes to safety in a water sport don't take your chances with the cheaper rope, buy the right stuff!
Water Sport Logo
how do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Jan 12, 2015 | Electrical Supplies
What is the purpose of a medicine ball with a rope attached to it?
Medicine balls with a rope allow you to develop rotational strength and power. Here is a short video clip that illustrates how to use this type of medicine ball to develop your rotational skills.
http://www.youtube.com/watch?v=1VzoaVtnZSk
Aug 05, 2012 | Exercise & Fitness
how do I repair the pull cord on a masport 600 mower - the cord snapped when I was trying to start it.
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assy. Depending on engine model you may hae to remove the air shroud with the recoil.
- Remove the broken rope assy from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rop burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end of the trheaded through rope.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assy.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Briggs & Stratton Briggs Stratton...
The recoil spring on my 1986 victa lawn mower will not rewind the starter cord. Is this easy to fix?
- Remove the recoil assembly. Depending on engine model you may have to remove the air shroud with the recoil.
- Remove the broken rope assembly from the spool by lifting the knot out of the hole and cut off the knot.
On the new rope burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assembly.
Kelly
Dec 03, 2010 | Briggs & Stratton Garden
855 people viewed this tip
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
