How to change your dryer from 3 wire to a 4 wire power cord. (short and...
MNTECH
By Guru MNTECH
Rank: Guru
Rating: 94%, 893 votes
posted on May 23, 2009
Very Helpful
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Was this helpful?
Yes
No
30 people thought this was helpful
Can you Help with these Dryers problems?
GE DBSR453EBWW / DBSR453EBCC Electric Dryer
Dryer makes noise when i put clothes in. rubbing squeeky...
The upper plastic trim piece that goes around the drum...
takes two cycles to dry. settings correct. has low heat
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions...
Dryer makes buzzing noise when I try to start. NOthing is...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
