Tip & How-To about Rubbermaid G780: PVA Sponge Mop
Four screws to attach mop G780 mop refill
Since the four screws which attach the mop refill to the G780 mop are impossible to find, and since they tend to rust, rub some lithium grease on the threads when you first get the mop and each time you replace the mop head.
Rubbermaid G780: PVA Sponge Mop Logo
how can I refill cartridge on mop?
The cartridge has a screw cap that you can open. Buy a gallon Bona floor cleaner and refill it.
Feb 17, 2016 | Bona Hardwood Floor Spray Mop W/...
clonking sound when im peddling backwards
please make this maintenance. God bless you
Depending on the amount of use, oiling your elliptical as much as once a month or once every 6 months can help prevent mechanical problems and avoidable repairs in the future.
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Aug 23, 2013 | Exercise & Fitness
how do you change rear freeze plug
first u have to remove the old frost plug either by using a puller which amounts to a screw be twisted into the centre of the plug be careful not to drive it into the block then retreival wud be near impossible then take ur new frost plug rub a lil white lithium grease around the lip that fits into the block get a socket to go into the centre of the plug then gently tap the frost plug into -place the hard part may be gettint to the plug sometimes they r tite well anywho gd luck
Sep 03, 2010 | 1989 Plymouth Acclaim
In the wash mode, when agitator is going left and then right. There is a loud rubbing, deep pitched squealing moise. It appears to be coming from the four rods that support the tub. Please help
If you take the front panel off, then the washer's top, you can un-hook those support rods (do only one at a time) and put a dolop of lithium grease on the top ball and socket area of each of the four suspension rods.
Feb 17, 2010 | GE Profile WPRE6100G Top Load Washer
replaced rear rotors and pads on 1999 4wd silverado, they now get burning hot , greased pins ok, whats wrong ??
make sure the pads move very freely inside the caliper bridge rust can build up and bind pads causing excess friction. never hurts to double check the parts purchased are the correct application.
Nov 19, 2009 | 1999 Chevrolet Silverado 1500
553 people viewed this tip
Top Rubbermaid Home Experts
Donni Steen
Tom Chichester
Are you a Rubbermaid Home Expert? Answer questions, earn points and help others
