Tip & How-To about Vehicle Parts & Accessories
Beautiful dashboard and vinyl trimmings
Why spend money on those fancy but expensive dashboard and vinyl trim cleaners?
The dash and trim on my 17-year old car looks like new and I never buy any commercial dashboard cleaners. Simply dilute a few drops of clean engine oil in lacquer thinners and apply. The thinners removes every trace of dirt and simultaneously deposits a thin layer of oil which also penetrates, assisted by the thinners, to keep your trim soft and flexible.
If the result is a bit tacky, you have used a bit too much oil. Simply remove using pure thinners and repeat with an improved mix until you achieve the best result.
Vehicle Parts & Accessories Logo
I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is half full. Machine is 9 years old but I will be happy to repair it if it can be?
9 years a good life for Washing Machine, I can't see why you have this problen , since you cleared it by taking sock out of filter, but expensive to get repairer to look at it , as 9 years old , get a new one . Better than spending money on a repair,
Mar 14, 2015 | Electrolux Washing Machines
My Philips TV is over 10 years old and has now got Green Hues all over the screen. Is this going to be an expensive fix or do you suggest a new TV now that my area is going over to digital shortly. I am on Freeview already.
You will spend lots of get this 10 year old TV repaired and it is still a 10 year old piece of electronics. The price of TVs has gone down so much that you can more than likely buy a brand new 32" LCD widescreen HDTV for what is will cost to repair this one. You could spend money to repair this one and then something else could go wrong. My advice it to junk it and buy a new one.
Jun 12, 2011 | Computers & Internet
changing stock stereo to new cd player
Why do you need to remove the dash the front trim should come off then go spend 10 bucks on a wire harness adapter wire it to your new radio then plug it in to the factory plug from the back of stock radio.
Apr 22, 2010 | 1995 Buick Park Avenue
Light spots on interior upholstery
Some vinyl if not cured properly will chemically change and cause spots or even runs. Make sure the spots are in the fabric and will not come clean. No chemicals to clean. If new, one year old, should be under warranty
Oct 16, 2009 | 2009 Ford Fusion
correct vinyl window installation
vinyle or no vinly, windows frame should be secured to the frame. The vinyl windows should have flange used to secured the windows to the outside wall if not to the frame. Looks like "CSE" didn't do a good job securing the windows. do you have trim on the outside? what knid of clualking? good thing is nothing happen in the last 3 years.
Since your contractor secured the windows to the frame, then you need to make sure all screw heads are protected and he did not make any unnecessary holes. all holes should be filled.
Jun 05, 2009 | Home
1,160 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
