Tip & How-To about Myron & Davis ADVD370 DVD VCDSVCDCD-R CD-RW MP3 PLAYER
How to connect your dvd to tv
This is for those who are struggling to connect rca cables to tv. Cables are normally color coded, yellow is for video (out from dvd snd in to the tv). Red and black sometimes white is for audio (left and right). Same thing here out from dvd in to the tv.
Car Audio & Video Logo
how do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
i am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
863 people viewed this tip
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Joe Ball
Joe Ball
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
