Tip & How-To about Blenders
The best way to clean your blender
I used to hate using my blender. I could make great smoothies or hearty soups but after I was done, I hated to clean it. The blender would be covered in small seeds or other small pieces of food that were stuck on. Plus, I'd be terrified of the cutting myself on the sharp blade (even when the blender was unplugged.)
So here is what you do:
1. Boil enough water to fill the blender.
2. Put a few drops of soap in the blender and plug it in.
3. Pour the boiling water over the soap in the blender, cover it and turn on.
You can let the blender run for two minutes, until it is clean or until all the little pieces are removed from the sides.
4. Rinse out with water and repeat if necessary.
And there you have it, using a blender just became a little easier.. since the cleanup is no longer a hassle.
Blenders Logo
Best blender brand for smoothies and juicing?
I would recommend to invest in a high quality blender that can perform all blending operations. If you're going to blending a bunch and need high speed blender to prepare smoothies and juices quickly. Vitamix will be a great option.
GroomNStyle Best Kitchen Blender Reviews 2015
Jul 29, 2015 | Blenders
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
how to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
Leaking Blender
yes you have a defective rubber seal on the pitcher base
Apr 16, 2009 | Back to Basics Blender Solution 5500...
1,101 people viewed this tip
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
