Tip & How-To about Building Materials
Keep your garage door in line with WD-40
Have you ever been worried after a heavy rain that rust will derail your garage door? I know I have. There are a few things you can do to maintain your garage door and one of the most important things is keeping it rust free. After a storm, once the door and the tracks it runs through have completely dried, take an old towel and clean out any residue that may have gathered in the track. This could be dust, pieces of leaves, spider webs, rust flakes etc. After you've cleaned it out, take a can of WD-40 and spray a generous amount on every inch of the track, including the parts that are inside and not open to the elements. You don't need to wipe it down afterwards because the WD-40 acts as a lubricant for the door and also prevents rust from building up in the future. I recommend doing this once a year to help maintain your garage door and to prevent annoying squeaking every time you open and close it.
Building Materials Logo
lots of rain water leaking into front passenger foot rest.
Are you certain it is rain water? It could be condensation from the A/C coil that fails to drain out of the drain pan, or possibly coolant from a leaking heater core. If you are certain it is rain water, depending upon the age of the vehicle, and possibly some other things, here are the possible options:
  1. Leaking door gasket.
  2. Leaking windshield seal due to rust
  3. Leaking windshield seal due to improper installation
  4. Leaking windshield seal due to acoustic (sound) over pressure (if you have extreme sound system with heavy bass)
  5. If you have a sunroof, if the drain hose comes down the passenger side door column, it could be leaking into the passenger compartment rather than drain through the floor pan.
Oct 29, 2015 | Cars & Trucks
Need help with no transmit receiver works fine Where do I find trouble shooting info? Jack kc5vs@yahoo.com
If it's been in storage for ten years, then there are two things to suspect. It either has killed the batteries because of no charge, so they over-discharged to nothing and probably have leaky batteries, or, depending on where you have stored the radios, they can simply corrode by moisture. I keep my two way radios in my kitchen display cabinet where I can see them to remind me to charge them every three months. And they're still working like new. Where did you store your radios, in the garage? Garages have the highest moisture because when you bring your car in after it has been in the rain, all that water on the car evaporates, and it's that evaporation that drifts inside a closed garage overnight which starts to rust all exposed metals and even connectors and printed circuit boards of... your radios. Cars should be left out in the rain at night and during the day the cars may be garaged but the door should be open to dissipate or dry the water on the car to air any moisture that's likely to be trapped in the garage. Observe and learn what a wet car can do to your valuable tools. Just leave the garage door open, even half will do, as long as air flows in to dry the car. But at night, leave the car outside.
Sep 13, 2014 | Radio Communications
I have a Merlin Powerlift 2500L that opens and stops half way. When disconnected from the door, the release rod travels the proper distance. However, when the door is connected, its upward movement stops halfway. What can be done to fix it?
Release the door from the opener and operate it by hand. Check for binding and excess heaviness of door. You may also need to increase the up force. Heaven only knows where it is on a Merlin.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
garage door opens randomly then closes
This is most commonly caused by a bad wall control, the wires going to it or a remote with a shorted switch. You must use a process of elimination. Heavy dew or rain will not cause this.
Oct 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
wet floor on drivers side fornt and back.
i had this problem too. it was a small rust hole in the wheel well. i took a pieace of aluminum flashing and a can of spray bedliner for trucks and patched it up. it works great! just a thought for you
Feb 02, 2009 | 1999 Buick Regal
789 people viewed this tip
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
