Tip & How-To about Cooking
How to cook plain white rice
Cooking something as simple as rice can be very difficult.
Follow these steps to make the easiest, fluffiest white rice:
1. Place one cup of white rice in a sieve and run luke-warm to cold water over it for a few minutes until the water runs clear, not chalky.
2. Shake out extra water
3. Put one tablespoon of vegetable oil in a pot over a medium heat and fry the rice for two minutes, constantly stirring.
4. Add one and half cups of water (can be room temperature) to the rice and stir once.
5. Turn the heat to low and cover for ten minutes.
6. Stir the rice and test softness. If it is still very firm in the middle, stir it and leave over flame for another 2 minutes. If it feels soft with slight firmness in the center, stir it and remove from the heat and leave covered for five minutes.
It is important to note that rice will continue to cook, even once it is off the flame. So you always want to remove it from the flame at least five minutes before you would consider it ready.
Good luck and enjoy!
Cooking Logo
i need insturctions on using the avon rice cooker for microwave
1. Before cooking, optionally rinse or soak the rice. This is necessary for some types of rice (especially brown rice, which is much harder than white rice), but it improves the flavor and texture of most types. To rinse, put the desired amount of dry rice in a container and fill it up with cold water. Use clean hands to sift the rice in the water. Drain and repeat. To soak, put the desired amount of dry rice in a container and fill it up with cold water. Let stand for 30 minutes, and then drain.
2.Mix rice and water in a microwave-safe container. A good place to start is two parts water for every part of rice (e.g., 2 cups rice to 4 cups water). You can adjust the ratio through experimentation, depending on how dry or moist you prefer your rice, the power of your microwave and the size/shape of the container.
3.Enhance the rice with flavor. Add salt, vegetable oil, olive oil or butter before cooking. A teaspoon of salt/vegetable oil or 1/2 tablespoon of butter should do the trick for each cup of rice.
4. Stir the rice mixture slowly with a wooden spoon. Combine the ingredients thoroughly. This is especially important if you have added other ingredients for flavoring.
5.Cover the rice. Place in the microwave and set the timer. Here are some suggested guidelines for a 700 watt microwave and white rice:
  • 1/2 cup rice, 9 minutes
  • 3/4 cup rice, 12 minutes
  • 1 cup rice, 16 minutes
  • 1 1/4 cups rice, 20 minutes
  • 1 1/2 cups rice, 23 minutes6
6. For brown rice, start with three cups of boiling water per cup of rice and cook it for 25 minutes
7. Let the rice sit in the microwave for five minutes after it turns off. Don't open the door. The steam will complete the cooking process. You might observe that the rice grains start to orient themselves vertically, like they're "saluting".
8. Fluff the rice with a fork and serve.
hop you enjoy it
Aug 15, 2014 | Kitchen Appliances - Others
Where can I find the instructions Manual?
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
Jul 30, 2014 | Nordic Ware Kitchen Appliances - Others
need directions on how make rice on my oster rice cooker
There are many types of rice. Follow specific directions for variety used.
2. Accurately measure rice and water then combine in rice bowl.
Pour specified amount of water in water reservoir. Cover and steam.
3. For softer rice, increase by 1 – 2 tablespoons the water mixed with rice
by the specified amount of water on the chart. For firmer rice decrease
water mixed with rice by the same amount.
4. Check doneness and consistency of rice at minimum time specified
for each type, stirring rice at the same time.
5. When checking/stirring rice, be careful not to drip the condensate into the
rice bowl which would reduce the quality and flavor of the steamed rice.
6. Use only clean water in water reservoir
7. Rice may be seasoned with salt, pepper or butter after steaming.
Combined In Rice Bowl Approx. Time
Type of Rice Rice Amount Water
(Minutes)
Brown
Regular 1/2 cup 1 cup 42 – 45
Parboiled 1 cup 1-1/2 cups 45 – 50
Long Grain and Wild Rice Mix
Regular (6 oz. pkg.) Mix 1-1/2 cups 50 – 55
Quick Cooking (6-1/2 oz. pkg.) Mix 1-3/4 cups 18 – 20
Instant 1 cup 1-1/2 cups 15 – 18
White
Regular 1 cup 1-1/2 cups 45 – 50
Long Grain 1 cup 1-2/3 cups 50 – 55
Oct 25, 2009 | Oster 5712 10-Cup Rice Cooker
lost my instruction book...want instructions to make rice in cooker...ratio of rice and water please
I have a Toastmaster 3 cup rice cooker but think the ratio would be the same.
Long grain white rice - 2 rice measuring cups - water to 2 cup line = 8 (1/2 cup) servings
3 rice measuring cups - water to 3 cup line = 12 (1/2 cup) servings
Long grain brown rice - 1 1/2 Rice measuring cups - water to 3 cup line - 6 (1/2 cup) servings
For fluffy rice: After cooker shuts off, allow rice to stand for approx. 15 minutes, covered, before serving.
Hope this helps
Oct 19, 2008 | Salton RA5 5-Cup Rice Cooker
manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
Cooking Pasta:
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
822 people viewed this tip
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
