Tip & How-To about Kitchen Appliances - Others
Be the cotton candy maker!
Here is how to operate a professional cotton candy machine.
First of all make sure you are renting the machine from a reputable company and that it arrives with a trained professional who knows how to operate it properly.
Also make sure that the machine is on a steady base and that no children or animals can get too close.
It is best to use a plug just for the machine instead of sharing it with other appliances.
To begin, turn on the machine's main power switch and fill the floss head with sugar.
It is very important not to fill the head above 90%.
Turn the machine's motor and then the heat switch on, putting the head dial setting on HIGH.
The sugar will start forming in about 45-60 seconds.
When the cotton candy starts pouring out you should have your cone ready. Dip it in the machine and pick the cotton candy by giving the cone a twirl that will gather the sugar around the cone.
Avoid rolling the cone around in circles as it is not the correct method to gather cotton candy.
When you are done, first of all turn off the HEAT and allow the motor to continue running at least 45 seconds, in order to get rid of the leftover sugar, and cool down the heating element.
Than disconnect the stabilizer screen and clips, rinsing them in warm water to dissolve the sugar.
You can now remove the floss pan from the main unit and rinse it off.
Children must not play with the cotton candy machine. It certainly is fun but it is not a toy.
Kitchen Appliances - Others Logo
my cotton candy maker dose not work and it has been two years! It's too late to return it now and I can't throw it away! what can I do! I wasted 30 bucks for this piece of junk! Help me fix it please!
With any device, it is helpful to know the brand and model number. I will provide a few links to some cotton candy maker's repairs but you have left out the crucial information. Not to worry. You can google "cotton candy maker" the brand and repair and possibly find some information. Even better, you don't have to have the machine to make cotton candy. I will provide links to that as well.
Make homemade cotton candy without machine
http://www.sheknows.com/parenting/articles/992989/make-homemade-cotton-candy
How to Repair My Tornado Cotton Candy Machine
Cotton Candy Machine Out Of Balance Ideas
Repair your Popcorn Machine Cotton Candy Machine Nacho Machine...
Oct 22, 2017 | Candy Kitchen Appliances - Others
How to make cotton candy with Elite Candyfloss machine? (Did not come with manual
Not sure if you have purchased it or hired for an event. Elite appears to be more of an event hire company and not makers of Candy floss machines. If you are looking for instructions on how to use these gadgets then this youtube video might be of help. It might help if you provide the model number of the appliance you have.
How to use Fairy Floss Machine
Does your machine look like any of the ones on this site.
http://www.etonmachine.com/catalog/router/htm/cid_1025/liid_698/catid_892/food-machinery/Candy-floss-machine.html
Aug 28, 2014 | Kitchen Appliances - Others
cotton candy maker will not power on
If you have checked to make sure it is plugged in, and outlet has power. The next thing to check is a circuit breaker in the front underneath the handle. A small white button to push.
If resetting the breaker, and it runs for a second then trips again, do not reset it again, this indicates a ground fault in the machine and it needs to be repaired by technician.
If the breaker doesn't change the operation (no power) then it should be repaired by a technician as there is no easy fix for the symptoms you have described.
Mar 21, 2013 | Gold Medal Products Gold Medal 3008SS...
nostalgia electric hard candy cotton candy manual
I believe you are looking for the Manual for the Nostalgia Electrics PCM805 Hard & Sugar Free Cotton Candy Maker which can be found online here:
http://nostalgiaelectrics.com/manuals/PCM805.pdf
Jun 17, 2012 | Nostalgia Electrics Hard Candy/Sugar Free...
Hi , I recently purchased your machine and would like to know how to flavour and colour the cotton candy. I did not receive any sugar in the box , so I'm not sure what to use. Please help. P.S - Can I use liquid colouring ?
Hi pandoramagic...
This is not the company that you bought your machine from, it is an "Answer Company" we supply answers to questions people have.
You need a special sugar in the machine (read below), and you can use liquid food coloring to color the sugar/cotton candy and different liquid flavors to flavor the cotton candy.
Typical machines used to make cotton candy include a spinning head enclosing a small "sugar reserve" bowl into which a charge of granulated, colored sugar (or separate sugar and food coloring) is poured. Heaters near the rim of the head melt the sugar, which is squeezed out through tiny holes by centrifugal force. Precolored sugar packaged specially for the process is milled with melting characteristics and a crystal size optimized for the head and heated holes; granulated sugar used in baking contains fine crystals which spin out unmelted, while rock sugar crystals are too large to properly contact the heater, slowing the production of floss.
The molten sugar solidifies in the air and is caught in a larger bowl which totally surrounds the spinning head. Left to operate for a period, the cottonlike product builds up on the inside walls of the larger bowl, at which point the machine operator twirls a stick, cone, or their hands around the rim of the large catching bowl, gathering the sugar strands into portions which are served on stick or cone, or in plastic bags. As the sugar reserve bowl empties, the operator recharges it with more feedstock. The product is sensitive to humidity, and in humid summer locales, the process can be messy and sticky.
Webpage for cotton candy supplies: http://www.epopcorn.com/cotton-candy-machines-cotton-candy-supplies.html
Please take time to rate me
Aug 31, 2011 | Helman Group Nostalgia Electrics RCM605...
723 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
