Tip & How-To about Plumbing
4 Tips for a healthy septic tank system
Living in a rural area and not having a connection to the sewage systems like houses in the cities or suburbs can make waste disposal a little difficult. That's where septic tanks come in they are made to take care of your sewage but if not cared for properly can result in a huge mess and stink. Following these 5 simple tips can help to keep your septic tank running properly and trouble free.
1. Keep rain water away
Make sure that you level the land around the tank so that rain water is diverted away from the tank. If you get too much water into the drain field it will become too soggy and won't neutralize liquid waste.
2. Trees mind their distance!
When trees grow too close to the septic tank their roots can cause damage to the system. A good rule of thumb is to not have any trees closer than 100 feet from the tank.
3. Toilet etiquette
This rule seems to be very obvious, you shouldn't be sending anything that shouldn't be going down the toilet must not go down the toilet. Things like wipes, or sanitary napkins and tampons will clog the septic tank and then you will have a big problem before you know it.
4. Stay away
For the system to function properly you have to make sure that it stays clear and undisturbed. This means don't drive over the drain field or build anything on top of it. Even pouring concrete or asphalt is a no, no.
If there is a problem with your system make sure to call an expert to come and look at it, under no circumstance should you open the tank yourself, there are harmful gases and bacteria in that require you to wear special gear.
Plumbing Logo
what are rural areas
A rural area is an open swath of land that has few homes or other buildings, and not very many people.
A rural areas population density is very low.
Many people live in a city, or urban area. Their homes and businesses are located very close to one another.
Feb 13, 2014 | CARNI FUEL DEFINITION 8 FL OZ 250 Softgels
What is a septic tank?
A septic tank is a key module of the septic system, a small-scale sewage handling system common in areas with no joining to main sewage pipes provided by local supervisions or private houses. Like TGWasteWater.com
Jan 28, 2013 | Plumbing
what are rural products
Rural means out of town or out in the coutry. Outside city: found in or living in the country typical of country relating to or characteristic of the country or country living agricultural relating to, characteristic of, or involving farming
Feb 08, 2011 | Home
Where do dispose of full toner waste bags?
It depends on where you live.
Do a Google search for " what's the best way to dispose of full toner waste bags?" And add your city,or state on the same line. It will return a list of places to recycle the toner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Ricoh Aficio CL3500N Laser Printer
475 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
