Tip & How-To about Kitchen Appliances - Others
How Do Knife Sharpeners Work?
Knife sharpeners are a way of preserving
knives and other such tools that have become blunt with use and therefore less
effective.
Sharpeners work by grinding the knife
against a hard, rough surface. Usually stone is the most common type of
sharpener but sandpaper (which has a soft surface but is hard), can also be
used.
You can take your knives to a knife shop
where they will sharpen them for you (on average once a year), but if you are a
keen knife user and want to keep your knives sharp and in excellent condition,
it might be worth buying a sharpener of your own.
To sharpen your own knives you’ll need to invest in a good whetstone. These are
stones that are available in fine, medium and coarse grits.
The sharpener will come with
instructions about the angle you need to place the knife at in order to sharpen
it.
You can also buy stones for polishing
and to complete the job properly, after you have sharpened your knife, you
should polish it.
Kitchen Appliances - Others Logo
mine broke, how do I get it replaced under warrantee?
please check out the instructions and the videos http://www.selectool.net/instructions.html to identify your problem. Most of the time, the tool is fine and there is a problem with either the knife or the insert. If you have tried all the suggested solutions, or your tool is truly broken, send them an email describing your problem. you will need $ 5. to cover shipping
Sep 24, 2015 | Sharp4Life.com SELECTOOL - Master...
Is there such thing as a knife that doesn't need sharpening?
There are some new knives on the market called "ceramic knives" that are made out of zirconium (the same stuff as fake diamonds.) They don't get dull because they are are wear resistant and should stay sharp for life. Be advised that ceramic knives are very expensive!
Dec 26, 2013 | Kitchen Appliances - Others
Is there somewhere in Manhattan that I can take bunch of knives to get sharpened?
Right before Thanksgiving I took my set of knives to be sharpened at Westpfal Henry in midtown. Here is their wesite: http://www.nysharpeningservice.com/
They did a great job and I had smooth cutting for all my holiday prep!
Do I need to sharpen my knife?
Every time you use your knife, the edge will become slightly less sharp, and you are more likely to injure yourself with a dull blade than a sharp one, as they can slip while you are working. Make sure you buy good knife-sharpening steel and use it each time before cutting with your knife it will also prolong your knife.
Jul 25, 2012 | Camping, Backpacking & Hiking
Hi, used a blade sharpener for my a2 horse clipper blades and they are still blunt. Do i sharpen between the teeth
no . The blades are sharpened by grinding away the base of the wear until the edges between the teeth are sharp. It also necessary for the tension between the cutting blades is correct other wise the cutting teeth ride up over the hair and will not cut. Have a person who does sharpening of knives ,scissors and blades sharpen the clippers for you as the machine will get it right.
Nov 18, 2009 | Makita 9820 - 2 Blade Sharpener
701 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
