Tip & How-To about Toshiba Satellite Pro P300 Notebook
BIOS password reset on a Toshiba Satellite P300 - 194
I guess I need to remove the CMOS battery to be able to reset the BIOS of the Toshiba Satellite P300 - 194.
My problem is that I cannot access the battery. Where is it located?
Is there any backward password I can use for that model?
Please help!
Thank you!
Toshiba Satellite Pro P300 Notebook Logo
Cmos reset jumper on a Toshiba 1675 Satellite laptop
You can do this by following one of the option:
http://www.wikihow.com/Reset-Your-BIOS
CMOS battery I think in your model is under keyboard which need to be remove to get access. O
Aug 18, 2015 | Toshiba Computers & Internet
TOSHIBA SATELLITE l.305 6050A2170401-MB-A03 NEED INSTALLATION GUIDE/HOW TO CLEAR CMOS UNABLE TO BOOT/RESET BIOS CLOCK
well this is not too much difficult ...1) go to bios and reset factory defaults ( i believe u know how to get access in bios ) 2) unassemble your mother board ... you will find a battery ( which we technicians call cmos battery) ..remove it and then insert it ( take 2 mint break)...
Jan 28, 2013 | Computers & Internet
toshiba satellite pro u400-130 bios password
  • The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
    To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
    Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
    After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computericon1.png, ideally, should no longer ask you for a BIOS password.
    It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password.
  • If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computersicon1.png that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Jan 26, 2013 | Toshiba Satellite Computers & Internet
BIO PASS WORD
Reset BIOS password, it can be done in two ways
Manual
Open the cover under laptop, remove the CMOS battery about 7 seconds, then plug it back. Turn on laptop, BIOS password will be lost. Perform setting date, time, etc.
Online (conditions: the laptop can desktop access)
Toshiba gives services, online flash BIOS. Download and install software ACPI Flash BIOS, according to model of laptop.
Example: Toshiba Satellite L305-SP6983R, software version: ACPI Flash BIOS version 2.20 for Satellite/Satellite Pro L300/L305/L350/L355
Nov 17, 2011 | Toshiba Satellite Laptop L655S5150
password bios toshiba 4000cdt
If you've forgotten your BIOS password, or if someone has changed the password on your Toshiba laptop without your permission, then there are a couple things that you can do to reset the password and access your computer.
Reset the CMOS
· The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computer, ideally, should no longer ask you for a BIOS password.
Use a Backdoor Password
· If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computers that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Dec 06, 2010 | Toshiba Satellite 4000CDT Notebook
4,508 people viewed this tip
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
