Tip & How-To about Cycling
Different Valve Types on Bicycles
This tip is to help you work out which bike valve you have.
Cycling Logo
Bike backfired and blew side off the oil box any idea what caused this
Angela, valve timing fault, Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
How to Diagnose Motorcycle Electrical Problems Dennis Kirk Inc
Service Manuals for Download in PDF
Mar 14, 2016 | ATVs
suzuki valve adjustment
http://www.carlsalter.com/motorcycle-manuals.asp How to Diagnose Motorcycle Electrical Problems Dennis Kirk Inc
Apr 14, 2014 | 2011 Suzuki Boulevard C50T
I have the bike pump and a Scott bike with these newer narrow long valves and cannot get the pump to work. The pump is short type with a metal lever at the valve end. Seems you extend the lever to fasten the pump to the valve? I push the valve deep into the pump female mount and then extend the lever? Then it seems to have a firm grip. BUT NO PUMP action - like the lave is closed? How do I do it? Thank.
Sounds like you are doing everything right on the pump end.
The culprit is probably with the Valve. There is a small tip on the end that needs to be unscrewed to allow air in and out. Loosen up the tip and give it a couple taps to make sure it is moving freely then try again.
Dec 14, 2010 | Serfas Cycling
Describe your 1998 FLHRC-I GAS TANK Problem: Bike
get compression checked on the cylinder for that pipe could be rings worn if compresion is fine valve guides could be worn or damaged hope this helps
Dec 16, 2009 | 2001 Harley Davidson FLHRCI Road King...
664 people viewed this tip
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
