Tip & How-To about Brill Razorcut 38 Push Reel Lawn Mower
Brill Razorcut As functionally elegant as a bicycl
Brill Razorcut As functionally elegant as a bicycle, the Brill RazorCut 33 Reel Mower ranks as a highly efficient human-powered machine. It's lightweight and easy to push - with no need for gas, oil or electricity!
MANUFACTURER'S INFORMATION
• Contact-free cutting, precision ground flame hardened bearing mounted blades • Cutting height: 0.7 - 1.8 inches (14-45 mm) easily adjusted, indicators both sides • Large hood protects overhanging flowers and shrubs • Rigid ergonomic handle with foam grip • Mows a 13-inch swath (33 cm) • Cutting technology: Blade cylinder, 5 blades • Weight: 15.21 pounds (6.9 kg) • Wheel diameter: 8 inches • Recommended for areas up to 2150 sq. ft. • Made in Germany • Two year warranty
Brill Razorcut 38 Push Reel Lawn Mower Logo
I need a replacement cable for a Gardenline Gladiator self-propelled lawn mower # 1911316
That number is not a Model Number. Looks like a Serial Number. Order direct from Gardenline or from the spares outlets listed.
Gardenline - Einhell - Genuine Spares and Accessories - Buy Online
www.einhelltools.co.uk/cmspage.php?page_id=61
  1. Cached
  2. Similar
Gardenline is the registered trade mark of Aldi GmbH & Co. KG. The list below details ALL Gardenline machines made under licence by Einhell UK. NB.
Gardenline lawnmower, trimmer or chainsaw types Mow Spares Ltd ...
www.mowspares.co.uk/products-by-make-brand/gardenline
  1. Cached
  2. Similar
Gardenline. Mow Spares Ltd supply a range of lawnmower blades, trimmer line, spools, chainsaw chains, etc that fit various mowers, strimmers, chainsaws ...
how to mend it .com - Bought at Aldi Gardenline lawn mower? - Free ...
howtomendit.com > Garden Tools, Lawn Mowers
  1. Cached
  2. Similar
Free repair help - bought aldi gardenline lawn mower. ... Warranty issues and spare parts for Gardenline (Aldi) products are handled by a company called ...
Gardenline (Aldi) Petrol Mower Questions & Answers - ProductReview ...
www.productreview.com.au > ... > Garden Line > Gardenline (Aldi) Petrol Mower
  1. Cached
  2. Similar
Gardenline (Aldi) Petrol Mower: 33 questions and 41 answers on Australia's ... cleaner) and have found no blockages,internal wear, or damage to any parts.
Buy Lawn Mower Spare Parts, Small Engines & Outdoor Power ...
https://www.allmowerspares.com.au/
  1. Cached
  2. Similar
Buy Lawn Mower Spare Parts and Outdoor Power Equipment Online from All Mower Spares. Largest range of products on offer in Australia. In stock + Free ...
Gardenline - Home
powertoolsupport.com/index.../gardenline-for-all-gaedenline-product-information
  1. Cached
Oct 16, 2013 - 190cc 4 Stroke Self Propelled, Variable Speed Petrol Lawn Mower with Side Discharge & Mulch Function - 49291. pdfimage. 50752 - 1200W ...
Lawnmower Spares - Lawn Mower Spares - Mower Spares
https://www.mowers-online.co.uk/Lawn-Care---Garden-Care/Lawnmower-Spares
  1. Cached
We sell a large range of lawnmower spares & accessories for garden and lawn care including lawn mower blades, mower batteries, engine service kits, grass ...
Nov 15, 2016 | Garden
reel mower wheels jam up
Does the reel turn off of the wheel motion?
May 12, 2017 | Garden
how to restring mower
Making the assumption that you are asking how to replace the pull cord on a recoil starter on a vertical power mower engine...??
You must remove the plastic cover in some cases, and the shroud over the top of the engine to gain access to the gizzards of the recoil starter.
That also means in most cases loosening and removing cylinder head bolts, and you MUST use a torque wrench to replace them to the proper tightness, so be prepared.
Once you have the shroud removed, on the underside will be a round reel that is retained by several bent over tabs. You have to straighten at least two of the tabs, and then you can remove the cord reel.
BE CAREFUL, as there is a flat spring inside that will jump out and possibly injure you.
You have to get the correct cord, string it through the handle in place of the old, cut it to the proper length, feed it back through the shroud, and wind it on the reel. Then you have to pre-tension the spring so that the cord will retract after you pull on it.
Once you have the cord routed and fastened to the reel, and captured on the pull handle, you can wind up the spring.
Unless you are VERY handy and have strong hands, I would not recommend you do the repair yourself. The spring must be tensioned, and held in place. It does not want to stay, and will jump out easily.
If you get it tensioned, the cord in place, then the reel must be put back into the shroud and the tabs bent back in place. Then the shroud has to be re-installed on the top of the engine, and the bolts tightened properly.tom
Jun 18, 2012 | Yard Machines Garden
where can i buy a handle for a daiwa ar2600 fishing reel? Or can another model reel handle fit?
Hello there and welcome to fixya
Here is a link to the diawa corp main page they have the parts that you l need and some phone numbers
Service Request Form
Download, print and fill-out this form. Include it with your reel when requesting warranty or non-warranty service. Parts Diagrams
Click here to find schematics of all Daiwa reels, current and discontinued. US Authorized Warranty
Centers
Factory Warranty Service & Parts
Daiwa Corporation
11137 Warland Drive
Cypress, CA, 90630 Exclusive Dendoh Power Assist Reels
Reel and Rod Services, Inc.
14645 SW 42nd St.
Miami, FL 33175
(305) 223-0811
http://fishingreelservices.com spacer.gif
Canadian Authorized Warranty Centers
Click here Frequently Asked Questions
Jan 02, 2012 | Sport & Outdoor - Others
how do I locate a replacement battery for my Brill Battery powered mower. Brill PowerAccu 24 Volt
Wow! That is one expensive battery ($149; but free shipping). I simply "Googled" it for you. You may want to do the same and see if you find a better price. But here's what I came up with right away:
http://www.peoplepoweredmachines.com/brill/electric-mower-battery.htm
Best of luck to you.
James
Aug 22, 2011 | Brill Garden
179 people viewed this tip
Top Brill Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Brill Garden Expert? Answer questions, earn points and help others
