Tip & How-To about Motorola MU21CV (1 Channel) 2-Way Radio
Battery and charger tips
The M series Motorola radios such as the MU21CV, come equipped with a NiCD rechargeable battery. This battery when fully charged should operate the radio a full 8-10 hour business day. The batteries have a life expectancy of 18-24 months.
The original Motorola battery has a date code in the white box above the stop sign on the back of the battery. The first digit is the year, and the next two are the week of the year. Example: 919 would be 2009, the 19th week. (Unless very old and it could be 1999)
When replacing the battery it is important to install the battery correctly. Put the top of the battery into the radio first, then slide the bottom into place. This method will cause the least pressure on the internal battery contacts.
If you battery's contacts are dirty or filmed, simply clean them with a pencil eraser. Do not use solvents or a knife blade on the contacts. The radio's contacts can also be cleaned with a pencil eraser.
The wall adapter style charger which came with the M series radio can burn out over time (much like a lightbulb). Replacement chargers are available. If your charger light is flashing, you most likely have a bad battery. If your charger light does not illuminate, you have a bad charger.
Replacement batteries and chargers are available, as is repair of this style unit.
Best regards,
eradiostore
Motorola MU21CV (1 Channel) 2-Way Radio Logo
Is it ok to use new NiMH battery packs with the original charging base?
Absolutely. NiMH batteries are direct replacements for Nicads - in use and in charging.
Dec 10, 2010 | Motorola T5410 (14 Channels) 2-Way Radio
need new battery and I have a NiMH battery replacement. Can I use it on my phone? I have model number 25838GE6-A.
NiMH is a universal replacement battery. It will work in place of nicad and other types of rechargeable batteries, and will work with virtually any charger
Dec 22, 2009 | Uniden Cordless Phone
Motorola t5000
I'm assuming you're using the NiCd batteries. NiCd batteries do not last forever and need to be replaced when they show a resistance to beign charged. To optimize the life of these batteries you need to let them fully discharge before attempting to charge them. This is impractical most of the time.
You have two choices:
1. Purchase a NiMH charger and AA batteries and use that INSTEAD of the CHARGER STAND and NiCd batteries. This type of battery can be recharged without the problems discussed earlier and will last longer... or
2. Purchase another NiCd battery pack.
Oct 24, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
MU21CV
It is likely your radio needs a new rechargeable battery.
Jun 24, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
3,001 people viewed this tip
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
