Tip & How-To about Dell Axim X51v Pocket PC
Dell PDA Battery Cover Warning Messages & Won't Power on
This is my 1st posting on this forum although I've done a lot of reading regarding the battery cover I think this is the correct solution.
To everyone that's having problems with the back plate battery cover warning messages or problems not booting up on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
welshcob
Dell Axim X51v Pocket PC Logo
2006 Kia Sedona Shaking & Vibrating Problems
From a quick search online and reading a little in some forums, it looks like the transmission fluid has to meet certain specs, and there may be only a few aftermarket fluids that do. Probably need to check to see if the fluid you used meets the Kia specs. You may have to do a drain and fill at least once if you contaminated it with an incompatible fluid.
You can use cheap carb cleaner to spray around manifold gaskets while the engine is idling to check for leaks. If it sucks the carb cleaner in, the idle will stumble and you found a leak.
Valve cover gasket shouldn't affect engine running. Might cause an oil leak, but that's about it.
Apr 25, 2017 | Kia Cars & Trucks
my phone now doesnt want to read my sim card i've change sim cards but still says no sim card
You may have some problem with your sim card socket or phones main board. Get it replaced from authorized service centre.
Nov 28, 2012 | Nokia 5800 XpressMusic Smartphone
Weird noises coming from the bottom part of the laptop
ovitzroei, Ram Memory modules do not make noise.
No moving parts,
Average SO-DIMM ram memory module as used in a laptop,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
The bottom has gold plated contact pins.
The black rectangles are DRAM chips.
They are mounted on a Printed Circuit Board.
The CPU also has no moving parts. (Central Processing Unit. Another name is Microprocessor, or simply Processor for short )
Although I have heard stories of CPU's going out, and playing a song remnant of 'Taps', or Brahms 'Lullaby'.
The harddrive used in your laptop is mechanical, with moving parts.
Information,
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=t6wTZhsffEE
Yes, possible it is/WAS the noise.
Methinks the Fan Assembly should be checked out,
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=4247575
Service and maintenance information > HP Pavilion dv3 Entertainment PC - Maintenance and Service Guide
[ Service manual ]
Unless it's still under warranty. Then you just send it in again, and may want to be a little more AGGRESSIVE this time.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 05, 2012 | HP Pavilion Computers & Internet
Battery latch
paper wedged in the sensor sometimes work. More extreme is 'surgically' removing the switch and connecting it up.... see aximsite.com for a guide.... otherwise take it to a technician.
Sep 19, 2008 | Dell Axim X51v Pocket PC
1,392 people viewed this tip
Alun Cox
