Tip for (PSS26MSRSS) Side by Side Refrigerator
GE / Hotpoint S xS Refrig: Will not dispense water
posted on May 07, 2009
MNTECH
MNTECH
Rank: Guru
Rating: 94%, 916 votes
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Comment by MNTECH, posted on May 20, 2009
Sorry, didn't notice that I put an extra zero in the part number. It should be a WR49X10173
Very Helpful
Was this helpful?
Yes
No
6 people thought this was helpful
Featured Tip
nxt prv
Add a Comment
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
Can you Help with these problems?
Answer
just bought ge side by side refrigerator last week. but now the light bulb is not working anymore. i... (More)
Answer
ge side by side ice maker and water dispenser just stopped working
Answer
at the same time every other day I get a de/defrost warning on my ref model TFX27FHE. PG&E... (More)
Describe your problem:
Select a Category:
Insert Link
Insert Image
Insert List
Insert List
Spell Check
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
