Tip & How-To about Work Safety
How to wear a hard hat properly
With so many different brand of hard hats there are all kinds of rules and for how a hard hat is meant to be worn. Never fear there are a few points that they all agree on and these are the ones that you should always keep in mind when you head off to work.
First you want to make sure that the suspension straps on the inside of the hat fit properly. You can adjust them by moving the pin to different holes much like you do to change a belt. The plastic of the hat isn't supposed to sit on your head like a regular hat. There has to be space between your head and the hat to help 'cusion' the impact of something hitting your head.
The ******** the back of the hat, one that sticks out lower should be tight on the nape of your neck. This strap helps in keeping the hat in place.
If your hard hat has a chin strap make sure that you have it adjusted properly because this will keep your hat on your head when bending over or looking up. The chin stap should sit on your chin suggly and not be looped under your chin in the space between your chin and your neck.
If you are finding it difficult to get the hat to fit properly never use fillers to make it fit better. You might just have a hat thats not the right size for your head. Using a filler can change the effectiveness of the hat and make it dangerous to use. Its better to ask for a new one then find your own solution.
Work Safety Logo
Different between white hat and black hat seo?
There is main point is a Whit hat SEO and Black hat:
White hat SEO is Best way ... But this is time taken and log time stability
When, Black Hat SEO is a un-natural way Like Stuffing of keywords, Copy Content, domain parking and S ping... etc. it's technique used then Spam works Like
Jul 31, 2015 | 2007 Honda Accord Sedan
What is a fedora hat?
A fedora hat is a felt hat that is traditionally worn by men. It's usually pinched at the front and has a brim. Michael Jackson gave fedoras good publicity in the 80s as he wore them in quite a few of his videos.
Mar 04, 2013 | Clothing Accessories
Is there a difference between men and womens cowboy hats? I want to buy one for my boyfriend and dont want to make a mistake.
Cowboy hats can be unisex, but there are some cowboy hats that are designed for women as they have more decorations, ribbons, jewels etc.
Jan 10, 2013 | Clothing Accessories
991 people viewed this tip
Top Work Safety Experts
Bobby Lewis
Bobby Lewis
Domenico Grillo
matt
matt
Are you a Work Safety Expert? Answer questions, earn points and help others
