Tip & How-To about Opera Software Browser
How to reset opera back to factory default setting (Profile reset)
The basic steps are 1)Backup necessary files 2)Delete opera6(configuration settings) file from profile directory. See details below.
What is profile reset?
Profile reset removes all your preference settings(like the options you choose in tools>preferences,custom toolbars,menu etc) and let opera rebuild it to the factory default condition automatically. The great advantage it brings that it destroys bad settings that you might have done or might have accumulated with multiple upgrade etc. This is very likely to resolve many issues users encountered with opera user settings.
What to do before profile reset? Do I need to backup?
You need to backup your files so that you can get back your data.
How to do the profile reset?
Close opera. You need to locate your profile directory (Help>about opera will show you the exact location). In windows xp, it is commonly at c:\documents&settings>username>application data>opera>opera>profile and in win vista its under in Win Vista C:\Users\yourname\AppData\Roaming\Opera. Note that "Application data" is a hidden folder in windows and you need to enable the opton to view hidden files and folders(open my computer>tools>folder options>view>show hidden files and folders). Once you have found the folder, just find and delete the file opera6.ini(configuration settings). Restart opera and opera will rebuild the profile settings.
Opera Software Browser Logo
how can I manage my icloud to gain more storage space without paying for more storage space?
Here are some methods to help if you don't have enough space on iCloud.
Method 1. Delete Photos/Videos from iCloud
One of the biggest data hogs to take up your iCloud storage space is the photos and videos. iPhone/iPad will automatically back up all your videos and photos to your iCloud. Therefore, deleting photos and videos from iCloud will free up iCloud storage a lot.
1. Tap on Setting > iCloud > Storage. Then tap on Manage Storage.
2. And then tap on This iPhone.
3. Under the Backup options, you will see Photo Library option, set the slider to OFF position.
4. Tap on Turn off & Delete to delete all photos and videos from iCloud.
Method 2. Delete Data & Documents
If you still find that there is no enough storage on your iCloud, you can try to delete these app-related documents and data to free up iCloud storage.
1. Go to Settings > iCloud > Storage > Manage Storage.
2. Select an app under "Documents & Data".(The first one genrally takes the biggest storage)
3. After selecting the app, tap the "Edit" tab in the upper right corner and then select the specific document to remove, or tap the "Delete All" tab.
Method 3. Close Unnessary Backups for Apps
If there are entire apps that you don't need to backup, you can do so by following the steps below to fix not enough iCloud storage for your iOS devices:
2. Select the device you want to manage the backup for.
3. Under "Backup Options", toggle apps off that you do not want to sync to iCloud.
Some other guides will be introduced in the following article. Please feel free to check them out.
How to Fix Not Enough Storage on iCloud for Your iPhone iPad
Oct 08, 2016 | Apple iPhone 5S
How do I manage and delete files on the iomega to make room for new backups?
when you plug in the drive it should mount it self and an external drive you can get to it by clicking on my computer and usually it will be labeled removable disk.
Mar 02, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
after email inbox configure setting in gts5233w asking DNS filed why
it is probably the configuration of your browser profiles. there is an error in configuring your browser profiles, check you browser profiles and input the right configuration.
you can also do these steps.
1. go to your menu, select internet
2. select settings
3. select clear cache
4. press ok
5. select empty cookies
6. press ok
7. select delete history
8. press ok
9. go back to your internet and press home and check.
if you still got the error,
try to delete your browser profile settings and create again
ask the right configuration from your network provider.
regards...
Mar 06, 2010 | Samsung Star GT-S5233 Cell Phone
hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Sep 17, 2009 | Microsoft Windows XP Professional With...
HP IPAQ POCKET PC
1st approach (Quick one!)
1. Soft reset your device
2. make a backup copy of the folder \SD-MMCard\MSMETADATA if exists.
3. delete the folder \SD-MMCard\MSMETADATA.
4. Soft reset your device once again.
2nd approach (Long one!)
If 1st approach did not work, restore the MSMETADATA folder and try the following:
Step Zero: BACKUP
- Make a full backup of your device (including storage cards). If you don't like to do a full backup keep at least a backup of all files and folders we are going to delete as indicated below:
Step One
-In the main device directory delete the file WMPInfo.xml
-Delete the \Application Data\Microsoft\Media Player\ directory and all of
the files in it including the WMDRM folder.
-Delete the \Music folder
Step Two
-Go to your SD card main directory and delete the file WMPInfo.xml
-Delete the folder \SD-MMCard\MSMETADATA
-Delete the folder \SD-MMCard\WMDRM
-Delete the folder \SD-MMCard\Music
Step Three
-Repeat step two for any other storage cards.
Step Four
-Refresh devices in WMP and the storages card should show up in the left tab
and in the sync window you can click "Next Device"
Hope this helps...
Feb 25, 2008 | HP iPAQ rx1950 Pocket PC
1,089 people viewed this tip
Top Opera Software Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
vimal
vimal
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Opera Software Computer and Internet Expert? Answer questions, earn points and help others
