Tip & How-To about Android ZEPAD 10" Tablet Android 2.2
Very very simple idea to reset zepad tablet if touch is not working
Turn on your tablet connect any keyboard.then use keyboard.go to setting and reset it.its very simple solution.
Android ZEPAD 10" Tablet Android 2.2 Logo
I hit the forget key I was trying to hook up my Bluetooth keyboard now I can't
This should be as simple as re-pairing the device. Put the keyboard in pair mode and your table into discovery Bluetooth settings and it should find it again.
Apr 30, 2017 | Tablets & eReaders
How do I connect irulu usb keyboard to my Visual Land Prestige Elite 7q tablet?
Make sure the tablet and keyboard are charged.
On the tablet, go to setting - it looks like a gear icon. Open settings and about the 3rd item down from the top of the drop down menu, you will see "Bluetooth." Make sure it is set to "ON"
Then go to the keyboard. It also has an "ON" button and press the botton. A tiny red light will blink slowly close to the button. There is a second "Connect" that must also be pushed - it is the "Connect" button and it will search for the Bluetooth signal from the tablet.
When it finds te tablet signal, you will see a message on the tablet screen [it must e turned on} instructing you to enter a 5 or 6 digit code on the keyboard. When you enter the code, a "Connected" signal will show on the screen.
Open a document and start typing!
I'm pretty sure this pertains to all tablets and keyboards.
Feb 12, 2016 | Tablets & eReaders
Why doesn't the keyboard appear on the screen?
If that keeps up try to resetting your device, that don't help connect to pc back up and factory reset it, try not to down load apps for your keyboard or any launchers keep it simple. Good luck
Jul 04, 2015 | Tablets & eReaders
I can set my key board to connect to my tablet but when I turn it off I have to reset it again everytime
Although the tablet should remember any Bluetooth devices connected to it when you shut it down, it still may take some time to enumerate the external devices and connect to them when restarted. Try making sure the keyboard is turned on before you start the tablet and give it a couple of minutes after the tablet fully boots up and see if it finds the keyboard by itself. If not, the keyboard may not retain its device pairing when disconnected, and you may not be able to fix that.
Jan 02, 2015 | Tablets & eReaders
How do you get the rca RCT6378W2 tablet connected with a Bluetooth keyboard
If your tablet is Bluetooth-enabled, follow the set up instructions that came with the keyboard. Basically, you turn Bluetooth on on both the keyboard and the tablet. Start the process of pairing and connecting from the tablet. If you are asked to enter a password/passkey and it is not specified in the keyboard's manual enter '0000' or '1234' (without the quotes). Note that the password is required only for pairing, therefore it will happen only the first time. If your tablet is not Bluetooth-enabled, you cannot connect the keyboard to it.
Dec 21, 2014 | Tablets & eReaders
2,652 people viewed this tip
Top Android Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
Lawrence Oravetz
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
