Tip & How-To about Evenflo CitiTour Double-Tattersall Standard Stroller
Pram or Stroller
Strollers with detachable infant car-seat carriers extremely practical. In the first couple of months, your baby can sit securely in the infant carrier while you go for a walk. As an added benefit, you can transfer your baby from the stroller to the car without having to disturb her, as you would with a pram. For older infants and even toddlers, you can use the stroller without the carrier. Most have seats where the back adjusts from nearly a full upright position to a full recline.
http://www.drspock.com/faq/0,1511,942,00.html
Evenflo CitiTour Double-Tattersall Standard Stroller Logo
i HAVE AND EDDIE BAUER 3 IN 1 DELUXE CONVERTIBLE CARE SEAT. I INSTALLED IT REARFACING YESTERDAY AND IT WAS SITTING TOO UPRIGHT SO I PUT 2 TOWELS UNDER THE BASE AND IT IS STILL TOO UPRIGHT. i SEE A LEVER THAT SAY PULL TO RECLINE BUT WHEN i PULL IT NOTHING HAPPENS. WILL THIS RECLINE FEATURE HELP LEVEL THE SEAT OFF? HOW DO I RECLINE IT? i HAVE A ONE MONTH OLD SO SHE CANT HOLD HER HEAD UP YET. i NEED HELP PLEASE.
One month old should not be in a car seat that allows for upright sitting. If it is convertible you have it in wrong. The seat should have a base unit which should be firmly fastened and the carrier should snap in and out of this base allowing you to carry your infant to and from the vehicle without having to detach the base every time you exit the vehicle. This is done so to prevent the unsafe installation of car seat under the stresses of time. If you seat is the kind that does not have a permanent base, go get one. It is very important that you do not modify the installation of any car seat for any reason. Placing a towel under the base as a barrier between the base and your seat is acceptable, but not to raise or lower the front or back as this may compromise its' design and decrease its' effectiveness. If you cannot figure it out, go to your local State Police Barracks where in most states they have a pregame designated for the safe installation of child infant seat carriers. This is very serious. The proper installation and choice in infant carriers can mean the difference of life and death in case of a relatively minor accident.
Jan 21, 2011 | Eddie Bauer 3-In-1 with Latch
1. How do I open and fold the DuoGlider stroller? 2. How do I attach an infant car seat?
The steering handle has a red switch on it. Pull the switch to the right and then twist the handle grip forward. The stroller should start to collapse.
Infant seats sit rear facing. You'll have to recline the stroller seat. Then the clip on the infant seat will grab the food tray and lock it in. Your stroller might have come with an additional strap to secure the seat once you have it locked.
Dec 18, 2010 | Graco DuoGlider 7924 Twin Seat Stroller
how to put the carseat into stroller?
For use with infant carriers only that click into a base when in the car. Place the carrier on the cup holder area, with infant facing you. It should nestle securely.
Sep 07, 2010 | Graco Baby Gear
how does the infant car seat connect to the stroller
It goes in the front seat it will click in place on the top of carseat connector that came with the stroller.
Aug 30, 2009 | Baby Trend Sit N Stand LX-7300 Travel...
718 people viewed this tip
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
