Tip & How-To about Home
Tips to clean sink mats
Usually sink mats get easily stained by tomatoe-based foods or oils, and the removal of those stains and greasiness is quite unpleasant.
Here are some tips to easily get your mats back to shape.
- One option is cleaning the mats with bleach. This process should remove about 90% of the stains, but will leave the mats a bit stiff. It also should always be done while wearing rubber gloves and in a well ventilated area.
- Another option is soaking the mats for 10 minutes in very hot water and dish soap and then scrubbing them clean.
- Putting them into the dishwasher with anti-stain or anti-grease soaps is also a good solution, and should work almost as well as the previous solution. They can also both be done, making the result even more satisfying.
- In addition to these methods, you can also make a paste of baking soda and white vinegar and use it as "soap" to scrub the stains. You can also let the paste sit on the stain for a bit, it should make it easier to remove the stain after.
Home Logo
I'm doing a project on my floor, a brown paper floor which requires staining and then 6-10 coats of polyurethane but the stain is oil base can i put a water base poly over top of this some people say yes but let it cure for 3-4 days
I have little experience of oil based stain other than knowing it is supposed to give long-lasting protection without further covering.
I prefer to use a spirit based stain and find it gives good results and once the spirit has evaporated it is quite inert and won't interfere with any subsequent finishes overcoating it, in fact it is designed to be overcoated.
I have used a water-based varnish and I found it particularly unimpressive compared to the usual alkyd resin or oil based stuff and it will be a long time before I use it again. Buying coloured varnish would mean you don't need the stain. I haven't tried it but I think a small amount of spirit stain could be added to oil based varnish...
Sep 28, 2017 | Washing Machines
I have a white rubber sink mat. How do I clean off the coffee and tomato sauce stains?
I tend to scrub my mat with detergent. Rinse it with warm water and leave it to dry off. You can also leave them to soak overnight with soap and then rinse them off in the morning. For really tough stains, I pour baking soda on top, let it sit for a bit and then scrub the mat. You can try leaving them in the sun, because sun bleaches white things.
Jan 10, 2013 | Home
I have been told to use denatured alcohol to clean the quartz sink. How is it diluted...what is the ratio to water? Thank you.
Denatured alcohol is only necessary for cleaning stains which are difficult to remove from your quartz sink, such as ink, oil-based stains or paints, etc. These stains should be dealt with immediately by scrubbing with a cloth dampened with denatured alcohol (undiluted).
Expecially difficult stains can also be dealt with by filling the sink with a highly diluted organic cleaner such as bleach and let stand overnight, however this method only recommended for well ventilated areas for obvious reasons.
Normal day-to-day cleaning can be managed with warm water, a liquid detergent and a soft cloth.
May 05, 2010 | Home
Washing machine smell
You need to use a steel wool with alot of ajax/comet and start scrubbing the entire inside of the tub.Its not going to wash out any other way.
May 21, 2008 | Kenmore 24032\24036 Top Load Washer
674 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
