Tip & How-To about Star Micronics TSP400 Label Printer
Lexmark All-in-One x3350
'Resetting' your Lexmark x3350 All-in-One
So I tried using my Lexmark today...  the power button is constantly on, and it won't do anything, My Lexmark just worked yesterday!
After calling that money grubbing Lexmark tech support line, they told me that I simply needed to unplug & then replug the power cord. I've only tried that over a dozen times, but gee tech support may know something that I don't so I tried for the 13th time!
And then they sincerely apologized and offered me a discounted All-in-One referb to purchase online.  Forget it !
I removed both ink Cartridges, then while holding down the power button, plugged the power cord back in and the display came back on, and the printer reset itself!
Thank you Diana for your post! I simply tried the same steps as for your Cannon. You just saved me over $100 bucks I don't have, and alot of frustration over a company that doesn't really 'support' your purchase of their product!
I really was NOT looking forward to getting another machine.
Good Luck to you all !
  TTonyTigger
Star Micronics TSP400 Label Printer Logo
My printer was purchased and is used in Germany. The on-screen instructions/options (eg, back to back print,etc) come up in German. Can I change that to english?.
Please follow the steps below to reset the Language on your Lexmark X3350 printer:
  1. Power off the printer.
  2. Hold down the power and + buttons simultaneously for five seconds. This will clear the language setting.
  3. The first prompt you will see is English. If this is not the language required, toggle the + and - buttons to navigate to your preferred language.
  4. Press the arrow button to select that language. The printer will save the new language setting.
Source: Wrong Language on the LCD Display of the Lexmark X3350
Sep 12, 2011 | Lexmark X3350 All-In-One InkJet Printer
change control panel of lexmark X3350 printer from Chinese to English
Hello. In order to change the language for your Lexmark X3350 printer you should follow these easy steps:
First of all, power off the printer and then hold the + and power buttons (at the same time) for 5 seconds.
This action will reset your language settings. You will now see an English prompt. If it's not there, search it by pressing the + button to navigate and press the arrow button to select it.
I hope I helped!
If you have any other questions, please leave a reply!
Thank you for using FixYa!
May 26, 2011 | Office Equipment & Supplies
Can't detect printer when scanning MBP
Maybe the scan software is not installed yet. The Lexmark scan software can only be installed using the installation cd that came with the printer. It's not available for download online since it's a big file. If you don't have the cd or you lost it, I suggest you contact Lexmark Technical Support for assistance.
May 05, 2010 | Lexmark X3350 All-In-One InkJet Printer
Lexmark x3350 says it's printing but nothing prints however I can scan.
Try to remove the cartridges from the printer. Close the cover. Unplug the printer from the power source and leave it unplug for now. Clean the nozzles of the cartridges using a damp paper towel. Plug the printer back in the power source. Printer should turn on automatically, otherwise, press the power button. When the printer's ready, insert the cartridges. Also, make sure the cartridges have substantial amount of ink left. If the cartridges are already old, maybe it's about time to replace them. Hope this helps. Good luck!
Mar 23, 2010 | Lexmark X3350 All-In-One InkJet Printer
The Lexmark X3350 printer paper jam
Try this:
turn off you printer
unplug the power cable
lift you printer up
while lifting, put it in an upside down position
then shake your printer from left to right for about a min. or 2
then put the printer back to its normal position
turn it on
then check if the issue persist.
Feb 26, 2010 | Lexmark OfficeCenter X3350 All-in-One...
979 people viewed this tip
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
ray gallant
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
