Tip & How-To about Home
A clean grater/zester with no trouble
Do you have the feeling that grating and zeisting your food is not worth the hastle of cleaning the tool afterwards?
Well, here are a few simple tricks that help you easily clean your grater and zester, remove all residues and keep you from grating your fingers attempting to clean it.
The first tip is to use oil. You can use a bit of olive or seeds oil and add it on the grater's surface. This way you will have a well-oiled surface that will not prevent the grating action but will help removing leftovers from the grater.
After the grating is done, a useful thing to do is brushing both its sides with a freshly cut lemon and then rinse. Most of the leftovers will come off like that.
Then take a toothbrush reserved for the kitchen and with hot water and soap brush the whole surface of the grater so to thoroughly clean it and then rinse it and let it dry completely before you put it away, to avoid rusting.
Another quick way to dry these kinds of items is to put them in the warm oven for 10 minutes.
Enjoy your clean graters and zesters!
Home Logo
Need directions to rebuild caliper
ok friend, for safetys" sake and whomever you drive around,...stop and think first if this caliper is really worth the hastle or just take what you have to the parts store and get a rebuilt one..even if you dont have the cash to get a rebuild theres a good chance this will only become an issue later on by leaking or not functioning when you really need it to its just that simple...to me its a safety thing..since I am not there to actually inspect the item for unseen damage when it blew apart..thats what I sugest you do,honestly I feel beter about just replacing it...
Jan 13, 2013 | 2008 Saturn Astra
cleaning the grates?
grill is easy to lift, i usually soak grill like that and then whipe off, that is usually sufficient.
if you have some really bdly ingrained bits, then spray it with oven cleaner, leave for few second and then whipe off, then wash as normal. if this is coated (teflon) grill, then do not use this method! soaking only!
hope this will help, if you find advice useful, please leave your comment and vote for me, thanx!
Jun 28, 2010 | Coleman Roadtrip Grill LXE 9949-750
clean stainless steel grates with wire brush
wire brush, heat up grill to warm and clean with wire brush. After you get the built up food and grease off remove grates and clean with soap and water to finish the job.
Sep 03, 2009 | Grilling
how to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
My dishwasher will not drain. Water is pooled in the washer.
Sometimes the Filter screens in the bottom, can become clogged with food particles. With a few simple houshold tools, you can disassemble it and clean the screens.
Jan 17, 2009 | Frigidaire 24 in. FDBB540 Built-in...
738 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
