Tip & How-To about Microsoft Windows 7 Professional for PC
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
Microsoft Windows 7 Professional for PC Logo
i have lost my drivers cd of msi Vclass drivers cd of ms7312 how to download from net for free
http://majorgeeks.com/DriverMax_d5260.html Win7/Vista/XP . DriverMax is a new tool that allows you to download the latest driver updates for your computer. No more searching for rare drivers on discs or on the web or inserting one installation CD after the other. Just create a free account, log in, and start downloading the updates that you need.
You can also export all your current drivers (or just the ones that work ok) to a folder or a compressed file. After reinstalling Windows you will have everything in one place!
Most of the situations when Windows is running slower are caused by faulty driver installations. Windows stores all versions of older drivers just in case you want to go back; sometimes it messes up older versions with more recent ones. The Export Wizard will only export the drivers you select by copying the needed files to a folder or a compressed ZIP file.
After reinstalling Windows all drivers will be back in place in less than 5 minutes - sparing you of searching, inserting disc after disk and losing precious time. The Import Drivers wizard allows you to install all the drivers that you exported earlier. The entire operation might take up to 5-10 minutes.
Just one single computer restart will be required after all drivers are reinstalled!
DriverMax is able to display a complete report of all drivers (versions, release dates) installed on your system. This feature can also be very useful when you want to analyze the differences between the drivers installed on different machines. Hope this helps
Apr 10, 2011 | MSI K8MM-V Motherboard
USB 3.0 drivers are crashing the system
Apr 06, 2011 | ASUS Rampage III Formula LGA 1366 Intel...
had new windows xp installed, now cant get my old email addess back.
When you installed Windows XP you wipe out all your old data and start afresh all over again.
You should have exported your email address book and saved it to an external storage device and then installed Windows and your email program. Then import your address book into your email program to restore your address book.
Mar 26, 2011 | Computers & Internet
I have a Win XP desktop that has a corrupt system file
If you know what file it is, you can try booting with a recovery disk - you can download the UBCD boot ISO for example - and copy it back.
Or, if you can enter at least Safe Mode, you can try running the SFC /SCANNOW command from the prompt.
Finally, ordinarily you can run a XP install on top of an existing installation without losing data. This is a last resort, though; some user personalization and info is bound to be lost.
Apr 16, 2010 | Microsoft Windows XP Home Edition
1,669 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
