Tip & How-To about LG WM-2277HW Front Load Washer
LE error code on LG washer
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
LG WM-2277HW Front Load Washer Logo
My machine stops and gives the error code LE
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble if you have any further questions message me back Thanks again Rick and sorry dont know why its typeing this way
Jan 15, 2011 | LG WM1812C Front Load Washer
LE flashes up
HELLO THERE:
Ok FIRST i believe this to be a Hall sensor that is either acting up or is failing you all together so.
here is what you can do about it to find out for sure.
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error: try it 1 more time
Now if you still get the error
The Hall sensor (part number 6501KW2001A) has failed. and will deffinatly need to be replaced
If you feel comfortable about ordering the part on lin e you can get the part from appliance parts pros.com ok or contact your local repar service center
I would also check to see if the machine is still under warranty ok
Hoe this isvery helpful for you
Apr 23, 2010 | LG WD-1045FH Front Load Washer
I have a LG washer dryer wd1433rd that keeps coming up with LE error....ive tried unplugging it...resetting it....is there anything else i can try?
CHECK THE BELOW LINK:
http://www.fixya.com/support/r2127066-le_error_code_lg_washer
Mar 31, 2010 | LG WM-2277HW Front Load Washer
LE service code it works for a minute and displays LE
Note: you do not list your model number, so the part number for your Hall sensor may be different than posted above. Always confirm part number via looking up from your specific model number before ordering any parts.
Oct 18, 2009 | LG Washing Machines
cycle stops after a few minutes,LE flashes on screen
May 09, 2009 | LG WM1814CW Front Load Washer
3,871 people viewed this tip
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
