Tip & How-To about Protron PLTV3250 32 in. LCD Television
Code for comcast universal remote for Protron PLTV3250
I used the code 10178 for the comcast universal remote so now I can use only 1 remote for volume and channel changing. I hope this helps!
Protron PLTV3250 32 in. LCD Television Logo
I bought an element tv that came with a nutek universal tv (used ofcourse) and now its come unprogrammed. I need the codes. Any help will be appreciated..
Codes to operate your Element TV:
Newer codes 5 digit:
11886
10178
11687
12183
Older codes 3 digit:
005
028
043
048
076
096
155
004
051
127
151
153
154
231
236
238
247
252
168
121
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your Element TV can be controlled with a universal remote and work with RCA remotes, Comcast, DirecTV, Charter, and more.
Read more: http://codesforuniversalremotes.com/remote-control-codes-for-element-tvs/#ixzz40ImSP8T7 Remote Control Codes For Element TVs Codes For Universal Remotes
Feb 16, 2016 | Universal Televison & Video
remote code for rca 50 in lcd 50lb45rq
For Universal Remote Control brands listed below, please use accompanying codes and refer to your Universal Remote Control UserManual for basic Instruction for changing TV code to operate the TV model.
Codes for DIRECTV: 0178, 10178
Codes for Time Warner Cable: 0178, 10178
Codes for Cox Communications: 0178
Codes for Comcast: 10178
Codes for Dish Network: 627
Codes for Fios Verizon: 0205, 0057, 0493, 0775
Jun 30, 2012 | Televison & Video
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
1,954 people viewed this tip
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
