Tip & How-To about Retail Supplies
Dig out your own treasure
Some people wrongly consider "treasure hunting" with the use of a metal detector, as a potential source of enrichment. However, as almost all metal detector treasure hunters will testify, this activity is almost completely of an entertaining nature and rarely brings any real valuables.
All metal detectors can be set to detect different levels of signals coming from the metals, buried underground. According to its settings, the metal detector finds bigger or smaller objects, of different metals, buried deeper or more superficially. What most people aim for is gold. Lost rings or chains, old gold coins etc.
Coins are the most common "treasures" found with metal detectors.
They can be found more or less easily both on beaches or buried in fields. In the latter case, it's easier to find older coins rather than modern ones; witnesses of history, lost in more or less ancient times. Many metal detector hobbyists like collecting them as historical tokens, engraved with images and scriptures from the past.
On the other hand, beaches are abundant with modern coins that people lose, for example, when dropping the wallet in the sand, or when shaking the towel, forgetting they had been hiding money or jewelery in it.
Rings are also often lost in the water and washed ashore by the waves.
Therefore, the two places on the beach that may prove the most fruitful, are the round-shaped areas where the waves touch, especially at their tip, and the farthest outskirts of the beach, where people usually set their towels and belongings, and where they are likely to shake off their towel, dropping "treasures".
Retail Supplies Logo
I am very curious about metal detectors; how they work etc. Can anyone explain it to me in simple terms but with a diagram?
Take a look at the Indepth Info Site - they have a fairly basic explanation but with a diagram that might help. But you're right - metal detectors are fascinating!
http://www.indepthinfo.com/gadgets/metal-detector.shtml
Feb 21, 2013 | Retail Supplies
i do not know how to work it at all. and how to connect the black wire and clip
To work it, all you do is to clip the gator to any metal suface on the car and start poking around on the electrical system. A light will come on when you touch a closed circut.
Hope this helps.
Feb 08, 2011 | Gb Electrical GB Automotive Voltage Tester...
687 people viewed this tip
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
