Tip & How-To about Clarion RAB250D
Wire connections for RAB250D w\casset radio
Here is the electrical wire connections for the Clarion RAB250D w\casset in dash radio by color code. Yellow w\fuse holder is battery + constant source needed to retain progamming memory. Black is ground - negitive chassis. Red is the ignition key on + switch source. The speaker connections you should note that they are paired colors. The black trace is the - negitive on the speaker polarity. The solid color is the + positive of the speaker polarity. Purple set is the right rear speaker. The Grey set is the right front speaker. The Green set is the left rear speaker. The white set is the left front speaker. There is one blue wire with a white trace which is a power output to a optional power amp. Isolate this wire if not in use. Cap the end or tape it.
Clarion RAB250D Logo
My clarion vz401 isn't holding memory. I believe memory cord is yellow or red? One is power and one is memory. Tried putting them color to color but it didn't hold memory. Then I tried feeding the yellow wire to the red wires but that didn't work either? Help me out
the red needs to be wired to a 12v+ ACC(dash accessory circuit) which is only powered when the ignition is on, the yellow needs to be wired to a 12+ constant(or, direct line, with in-line fuse to battery +), whether the car is on or off. if the wires behind the dash both lose power when the car is off, the yellow lead will have to be re-ran, possibly thru the firewall, and to the battery(with appropriately insulated wiring, and an appropriate fuse.
instead of going thru all the trouble of running to the battery, it may be beneficial to get a multi-tester ($20-40, usually), in order to test the wires behind the dash for a 12v+ constant and a 12v+ acc.
Dec 28, 2014 | Car Audio & Video
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than the old. I have only two speakers. Can you give me the color code for the wiring ?
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
I have a 1993 chevy lumina that I want to put a Clarion radio in, the original was stolen along with the wiring harness, so I only have bare wires exposed, what parts do I need to purchase?
You can purchase a small package of crimp connectors for the electrical connections. If the wires are exposed, you can connect them using this following list of connections.
These are the CAR's wiring (not the radio unit)
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Look on the owner's instructions for the radio, the wiring diagram should be there. If not you can visit the clarion website with the radio model number to get the color codes for the radio wiring..
Simply crimp each to the correct corresponding wire. You may have a few extra.. the antenna power, or the radio mute.. just cap the ends of these..
K
Sep 17, 2009 | 1993 Chevrolet Lumina
Clarion RAB250D w\casset need to set clock and stations.
While pressing the BAND button, press the DISP button for 2 seconds or MORE to enter the clock editing mode.
To move between the hour and nimute fields, use the left (hour) and right (minute) buttons.
To store the clock setting, press the BAND button.
Also to change between manual tuning and seek tuning press and hold the BAND button for 2 seconds of more. "SRCH" will appear in lower side of display when in search mode.
To preset a station manually press the BAND button to select the band at which to store the station (AM, FM1, FM2, FM3).
Tune to the desired station to be preset
Press and hold the corresponding preset button (1-6) for at least 2 seconds to store the station into memory.
Apr 26, 2009 | Clarion RAB250D
I'm looking for a wiring diagram for a Clarion drx5675 does anyone know where i can find one? Or can someone give me the color coding to the wiring so i know where they go to, thx
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Feb 21, 2009 | Clarion RAB250D
1,062 people viewed this tip
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
