Home | All Products | K-jam Smartphone | Tips
Phone won't charge at all? No lights? Fix it here!
PCTServices
By Guru PCTServices
Rank: Guru
Rating: 86%, 389 votes
posted on Oct 02, 2007
Very Helpful
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
Was this helpful?
Yes
No
6 people thought this was helpful
Comment #1
posted on Aug 12, 2009
sailingfc
By Apprentice sailingfc
Rank: Apprentice
Rating: 0%, 0 votes
I have an HTC 8125 and your solution worked like a charm. I modified it slightly though. I used a Nokia wall wart instead of a USB cord. The Nokia puts out the same voltage as the battery, 3.7 volts. A standard paperclip fits right down the center of the plug and a second paper clip wraps perfectly around the barrel of the plug. I held the paperclips to the appropriate terminals for a count of 20 and then put the battery in the phone and plugged it in. Took about 2 hours to charge up. Now I think my battery is better than before, it's been 24 hours and the remaining power is still above 95%. This is a two year old factory original battery and only the second time that I have accidentally completely discharged the battery. They say that you don't need to cycle a Li-Ion battery, but I think it does help to do it once in a while.
You saved me from buying a battery.
THANKS.
Comment #2
posted on Aug 08, 2009
agenticarus
By Apprentice agenticarus
Rank: Apprentice
Rating: 0%, 0 votes
This really worked! Excellent advice. Another device I had plugged into my computer at the same time started flashing and saying it was charging so I would suggest unplugging any other devices before you try this.
Thanks Peter!
Comment #3
posted on Apr 24, 2009
loucypher
By Apprentice loucypher
Rank: Apprentice
Rating: 0%, 0 votes
You can do the same thing with a 9volt battery. and there is no need to strip a usb cable - i also think its safer.
I got this solution from a post on another site. just tried it on 2 dead imat batteries and i cant believe it was so easy. - i wish i had of known this b4 i bought new batteries ;)
Can you Help with these PDAs problems?
i-mate K-jam Smartphone
call records not storing
i have imate jasjam mobile when i switch on my mobile only...
I lost my installation cd and left my charger at a hotel...
want to upgrade to 6
i lost the installation cd for my imate kjam cell.
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
