Home | All Products | 8125 Smartphone | Tips
Phone won't charge at all? No lights? Fix it here!
PCTServices
By Guru PCTServices
Rank: Guru
Rating: 86%, 382 votes
posted on Oct 02, 2007
Somewhat Helpful
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
Was this helpful?
Yes
No
5 people thought this was helpful
Comment #1
posted on Oct 15, 2009
sabprism
By Apprentice sabprism
Rank: Apprentice
Rating: 0%, 0 votes
Just sacrificed an old USB mouse (it had two black wires, one full length insulation one only black at end) I used the red and full black wires and only held them on for about 20 seconds as recommended. It worked perfect.
Dropped the battery into the phone, pressed the power button and BAM! It powered up and is now charging. This was after letting it plugged in to a wall outlet for over 48 hours and nothing, no charge was applied.
Now it is charging and I have labeled and printed this tip as USB Jumper Cables, stored them away for future use just in case!
Thanks, a world of thanks!
Comment #2
posted on Oct 13, 2009
michael36yrs
By Apprentice michael36yrs
Rank: Apprentice
Rating: 0%, 0 votes
worked for me but held the wires there for like 2 - 2 1/2 minutes after the 20 seconds didn't work & did further web research.
Comment #3
posted on Sep 22, 2009
oldbaldieone
By Apprentice oldbaldieone
Rank: Apprentice
Rating: 0%, 0 votes
Excellent it worked first time on a loox N560 battery that I though was kaput. They really should have done something about the charging system.
Comment #4
posted on Feb 13, 2009
snwbrdr1121
By Apprentice snwbrdr1121
Rank: Apprentice
Rating: 0%, 0 votes
i had put the black wire where the - is and the red wire where the + is and held it for 20 seconds but yet it still wont power up and ive retried several times
Comment #5
posted on Jan 04, 2009
saladeverte
By Apprentice saladeverte
Rank: Apprentice
Rating: 0%, 0 votes
Thanks!!
I've tried with a Alcaline battery 9V+ aluminium wire (I didn't want to destroy usb cable...).
Left it for 30 seconds & battery restart with this electroshock therapy :)
Comment #6
posted on Jan 01, 2009
clhatch13
By Apprentice clhatch13
Rank: Apprentice
Rating: 0%, 0 votes
wow wow wow....i bought a refurbished i760 off of ebay. i was worried that they sent me a dead battery, bad charger, or the phones connections were bad.
Well, i tried this trick....it would charge it a little bit each time but never would charge after plugging it back into the wall charger. After doing this a good many times, it finally charges now!!!
Incredible fix!!! Incredible!!!
Comment #7
posted on Dec 06, 2008
elementsk83r
By Apprentice elementsk83r
Rank: Apprentice
Rating: 0%, 0 votes
dude thank you so much it works now
Comment #8
posted on Jul 16, 2008
rock_lee317
By Apprentice rock_lee317
Rank: Apprentice
Rating: 0%, 0 votes
hey i apreciate it. having problems with it loading up but it is finaly charging. thanks abunch man. :)
Can you Help with these PDAs problems?
Cingular Wireless 8125 Smartphone
my 8125 cannot use sd card it always says memory card not...
all sound has stopped working...
i am using cingular 9125, the problem is that its back...
granted this phone is super old. it wont even make a...
while resetting the system screen went to blank but i am...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
