Tip & How-To about Cingular Wireless 8125 Smartphone
Add 802.11g (Wireless G) network access
Google a program called total commander. download and install it on your phone.
Now open total commander. Listed on the very top of the folders list will be \\
-Click on \\
-then click registry (you are now in the devices registry, be careful not to change other things)
- select hklm (this stands for Hkey local machine)
you need to go to this location
HKEY_LOCAL_MACHINE\COMM\TNETWLN1\PARMS
(so you would choose comm, then scroll down to tnetwln1, then select that and scroll down to parms and select parms)
then assign the follow changes to the keys listed in PARMS...
Assign a value of 1 to dot11SupportedRateMask
Assign a value of 8 to dot11SupportedRateMaskG
Perform a soft reset (do this by holding the power button for roughly 6 seconds, until a box comes up asking you if you want to shut off the device. Turn it off, then turn it back on and the changes will go into effect)
Then simply try to log on your router
Peter
Cingular Wireless 8125 Smartphone Logo
Need help to set up WiFi on 8125 smartphone
You may need to upgrade the htc wizard to use 102.11g networks. You can do this yourself if you follow these steps. Google a program called total commander. download and install it on your phone. Now open total commander. Listed on the very top of the folders list will be \\ -Click on \\ -then click registry (you are now in the devices registry, be careful not to change other things) - select hklm (this stands for Hkey local machine) you need to go to this location HKEY_LOCAL_MACHINE\COMM\TNETWLN1\PARMS (so you would choose comm, then scroll down to tnetwln1, then select that and scroll down to parms and select parms) then assign the follow changes to the keys listed in PARMS... Assign a value of 1 to dot11SupportedRateMask Assign a value of 8 to dot11SupportedRateMaskG Perform a soft reset (do this by holding the power button for roughly 6 seconds, until a box comes up asking you if you want to shut off the device. Turn it off, then turn it back on and the changes will go into effect) Then simply try to log on your router Peter
Jul 26, 2007 | Cingular Wireless 8125 Smartphone
618 people viewed this tip
Top Cingular Wireless Computers & Internet Experts
David Payne
David Payne
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
