Tip & How-To about White Sewing Speedylock 1600 Mechanical Sewing Machine
White speedylock
I bought this machine new and have had nothing but problems it has been in the repair shop 3 times already at $79 a visit - i contacted white about this and they have not even responded ?????????????? i gave up and bought a new regular singer
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
I have a Bernina Record bought in 1969 which needs a new motor. Any idea where I can find one?
We do have such motor in stock both new and rewinded. Please visit www.sewingmachine.com.au for more information in purchasing this part.
Dec 02, 2011 | Sewing Machines
timing
That needs a repairman because you have to reset the gears, if it is still having the same problem take it back to the repair center and they should fix it again for free because they did not solve the problem. I am sorry to tell you but those machines have been nothing but headaches to my customers, many have just bought new machines (our shop sells Brother and Babylock).
Jul 03, 2009 | Singer CE-200 Quantum Futura Computerized...
Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
May 01, 2009 | Singer 5050 Mechanical Sewing Machine
WHITE 2037 TENSION ISSUE...
Okie Dokie..... Here's the way I see it.. The repair center was of little or no help to you . So, I will try to do my best..
First thing you need to do is unthread your machine and set the tension to 4.. Rethread the machine up to just before the needle.
When you get that far, put the presser foot down. If your thread pulls right thru easily, it is not threaded thru the tension wheel right. It your thread is hard to pull thru with the presser foot down, then it is threaded right.
General rule of thumb..
Loops on the bottom-- problem on the top
loops on the top--- problem on the bottom.
Hope this helps..
Mimi
Dec 15, 2008 | White Sewing 2037 Mechanical Sewing...
1,063 people viewed this tip
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
