Tip & How-To about Samsung Galaxy Tab 2 7.0
How to do screen shot on Samsung Galaxy Tab
Just hold the power button key and the lower volume button key. Then press it together then hold for a few seconds. Try it!
Samsung Galaxy Tab 2 7.0 Logo
get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
How do I hard reset RCA 10" tablet??
hold down all buttons...power camera volume all of them together
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO COMMAND. So, can someone help me????????
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
2,188 people viewed this tip
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
