Home | All Products | 24 in. LDF 7811 Built-in Dishwasher | Tips
Unable to correct error code on LG Dishwasher (IE, E1, or other code)
MNTECH
By Guru MNTECH
Rank: Guru
Rating: 94%, 851 votes
posted on Apr 29, 2009
Very Helpful
If you are getting a IE or similar error on your LG dishwasher and have not been able to solve the problem using information based on that code, check the serial number of the dishwasher. If the first three numbers are between 501 and 702 you may have this problem:
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Was this helpful?
Yes
No
9 people thought this was helpful
Comment #1
posted on May 05, 2009
meyerjr
By Guru meyerjr
Rank: Guru
Rating: 91%, 205 votes
This is incredibly helpful information for owners of LG dishwashers! Thank you for posting it here.
Can you Help with these Dishwashers problems?
LG 24 in. LDF 7811 Built-in Dishwasher
Two days ago, my GE Spacemaker dishwasher (about 2 years...
can not get unit to start cycle. lites up but wont start
I moved into a house with an LG 3850DD3006E dishwasher. It...
attaching counter clips to dishwasher
Hi i have a lg diswasher thats not working it has a e4...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
