Tip & How-To about Computers & Internet
How to change your skin on minecraft mac
Double click on trackpad and press Get Info, go to Name & Extension, then change the skin you want to char.png, then go to Finder, Your Home(like ex: jpledger), Library, Application Support, minecraft, texturepacks, go in to your texture pack, press mobs file, then drag the skin called char.png in to the file, there is your skin! Woppss, almost forgot to tell you, you have to keep Minecraft closed the whole time you are doing this!
Computers & Internet Logo
how can i remove my cd ?
In the Finder (on your Desktop), you can usually remove your CD by
  • simply dragging the icon for the CD to the Trash (Trash icon will turn into an eject icon).
  • You can also right-click (Ctrl-Click) on the CD icon and Select "Eject" from the dropdown menu.
If your CD doesn't eject,
  • shut down your laptop;
  • press and hold the mouse key (press the click on the trackpad);
  • while holding the mouse key (pressing and holding the click on the trackpad), press the power key to restart the computer;
  • let go of the click on the trackpad after the CD ejects.
Mar 11, 2015 | Computers & Internet
profile service service will not allow me to logon
First of all start your computer in safe mode. This can be achieved by pressing F8 during the start-up of your computer. If this is done correctly you'll get a menu where you can choose to start your computer in safe mode.
After it is booted in safe mode follow these steps:
  1. Click Start, type regedit in the Search box, and then press ENTER.
  2. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
  3. In the navigation pane, locate the folder that begins with S-1-5 (SID key) followed by a long number.
  4. Click each S-1-5 folder, locate the ProfileImagePath entry in the details pane, and then double-click to make sure that this is the user account profile that has the error.
    • If you have two folders starting with S-1-5 followed by some long numbers and one of them ended with .bak, you have to rename the .bak folder. To do this, follow these steps:
      1. Right-click the folder without .bak, and then click Rename. Type .ba, and then press ENTER.
      2. .bak, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493039.png" alt="2493039" title="2493039">
      3. .ba, and then click Rename. Change the .ba to .bak at the end of the folder name, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493040.png" alt="2493040" title="2493040">
    • If you have only one folder starting with S-1-5 that is followed by long numbers and ends with .bak. Right-click the folder, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
      1. .bak, and then click Rename. Type .ba, and then press ENTER.
        [img src="http://support.microsoft.com/Library/images/2493038.png" alt="2493038" title="2493038">
  5. Double-click the folder without .bak in the details pane, double-click RefCount, type 0, and then click OK.
  6. Click the folder without .bak, in the details pane, double-click State, type 0, and then click OK.
  7. Close Registry Editor.
  8. Restart the computer.
  9. Log on again with your account.
Dec 24, 2013 | Computers & Internet
MacBook (10.5.6) saved 3 documents to ''Apple - recent items'' today instead of to my memory stick. I can see them, but neither open them nor send them back to my memory stick. ''Help'' gives a convoluted method of using ''Finder'' or ''Applications'', but both seem too complicated for my tiny Scots brain! Help!!!
You can use finder, but I would try Spotlight. Basically click the magnifying glass in the upper right part of your screen and search the name of the file. It will list all documents and programs that have that name. then open the containing folder and cut and paste to stick. The following is a video describing how to use it. http://www.dummies.com/how-to/content/how-to-search-for-files-and-folders-on-a-mac.html
Jan 12, 2010 | Apple Computers & Internet
The resource cannot be displayed The page you are looking for cannot be opened by your browser because it has a file name extension that your browser does not accept. -------------------------------------------------------------------------------- Please try the following: Change the Multipurpose Internet Mail Extensions (MIME) or security settings of your browser to accept the file name extension of the requested page. Note that your browser might currently be configured in a highly secure mode that protects your computer. Please read the Help for your browser before changing any settings. HTTP Error 406 - Client browser does not accept the MIME type of the requested page. Internet Information Services (IIS)
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem, make sure that the Accept header of the client request matches the MIME type that is specified for the requested content file name extension on the server. To do this, follow these steps: 1. Start IIS Manager. To do this, click Start, click Run, type inetmgr.exe, and then click OK. 2. In IIS Manager, expand the server name, expand Web sites, and then click the Web site that you want to modify. 3. In Features View, double-click MIME Types. 4. Double-click the MIME type that you want to modify. 5. In the Edit MIME type dialog box, type the appropriate MIME type for the content file name extension in the MIME Type box.
Note You can also set the MIME type of the content file name extension to */* to accept any MIME type
Sep 29, 2008 | Computers & Internet
946 people viewed this tip
David Payne
David Payne
