Tip & How-To about Bose Wave Radio
Cleaning stuck control buttons on Wave Radio/CD
Mine was made in 1999 and the push buttons have become "sticky"
over time (dust, humidity, whatever) and the CD tracks would skip.
The buttons are on top on my Model AWRC-1P (it's not a front-loading
CD model) so there is no access to do maintenance.
I called BOSE customer service (very helpful and pleasant folks) to
hear that there is no "fix" to the sticky button issue. Wipe the case
with a very damp cloth to take off surface dirt, and that's it.
I asked if I could use my CleanSafe aerosol "Dust Remover" that I
have to blast dust and lint from my computer - yes, was the tech's reply
but - - - ONLY IF IT IS "moisture-free" (which it is!) Point and shoot
the blasts of air into the buttons a couple of times and, voila!! No
more sticky functioning! Now the CD tracks move up and down
without a problem, good as new (almost, it is ten years old).
The Bose tech said that usually the CD player goes out in time. They
only can be serviced by Bose (about $125 for an overhaul) in Framingham MA - they do offer (or had offered) a trade-up exchange for $199 to a
new CD/radio but without the buttons and other features of my old
model. Call 800-637-8781 for Bose Service (M-F Eastern time).
Hope this is helpful info, it solved my sticky buttons problem!
Bose Wave Radio Logo
I have an acer8930g with cinedash media console. however when using the next track button with spotify it often skips 2 or 3 tracks instead of just skipping the current track.
It sounds as if you should re-install the program. Or you may just have a sticky keyboard. or the key repeat time is very fast. Try looking in the control panel for your operating system and adjust it from there.
Apr 12, 2013 | Acer Computers & Internet
My sony MHC-GX250 says relay is it possible that it is causing my system to keep skipping tracks and randomly jumping ??
Mine says that all the time and it doesn't skip like that.. try using some air duster in the back and cd tray.. mine actually quit playing cds at one point.. my friend said it was the "dust cover" or something like that by the eye..
Feb 06, 2011 | Sony MHC-GX250 CD Shelf System
CD player won't play after pressing the play button on all tracks
This problem is usually caused by dust or smog accumulating on the laser lens assembly. Unplug the unit and remove the top cover. Take a cotton swab and wet one end with glass cleaner. Wipe it gently across the lens (do not apply pressure). Use the other end of the swab to dry the lens. Reassemble the unit and test for skipping or non-playing discs.
Feb 02, 2009 | Audio Players & Recorders
cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
cdj 1000-mk-2
Could be either the Track skip switch has collapsed and is thus over sensative or the button bank is broken and the track skip switch is being pressed when the cue button is used.
Could also have liquid spillage on the circuit board which cause all sorts of random problems
Oct 21, 2008 | Pioneer CDJ-1000 CD Player
1,344 people viewed this tip
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
