Tip & How-To about Toshiba 50HX81 50" Rear Projection Television
Turn on your 50 inch Toshiba
Take the back off and blow a hair dryer in the cavities where the wiring sits. This worked for me many times.
Pic
Toshiba 50HX81 50" Rear Projection Television Logo
help my monitor pixels are a mess lines going through
your panel is faulty and has loose connections in the wiring from the card to the actual lcd panel sides. You could try opening it up and blowing on the sides with a hair dryer to see if they will reseat. Has the unit been in high heat lately? I have seen this occur in cases where the screen has been sitting in a hot car and allowed the connections to loosen from heat that way. There are companies that will reseat the connectors if you can not get it going, but it is somewhat expensive. Try the hair dryer though first.
Oct 07, 2014 | Envision Computers & Internet
Best Blow Dryer 2014 How to choose?
Babyliss Pro Tourmaline Titanium 3000 Dryer Is the best blow dryer its consumer review rate 4.3 out of 5 you can get more best branded hair dryer in the world.
Best Hair Dryers 2014 Review 10 Best Hair Dryers 2014 Review Buy it for curly hair
Aug 24, 2014 | Dryers
What is special about ionic hair dryers?
I read a review top ten hair dryers which is the best and professional blow dryer for healthy hair. everybody can choose one. 10 Best Hair Dryers 2014 Review Buy it for curly hair
Feb 04, 2013 | Health & Beauty
whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Jun 14, 2009 | Whirlpool Dryers
815 people viewed this tip
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
