Tip & How-To about Toys
Solving any jigsaw puzzle no matter how big
Big puzzles can at first seem to be very daunting, but when you complete it you feel a great sense of accomplishment. It doesn't matter if your puzzle is 50 peices or 1000 pieces using the same technique you are able to solve the puzzle no matter how intricate the image may be.
Always start by separating all the pieces according to whether they are edges or not, when you have separated all the pieces take the edges and start putting together your boarder. This helps give you a nice starting point and it gives you an idea of the size of the puzzle.
Once the border is completed if you are working with friends or family you can split up with image inside, like if its a landscape one could do the sky while another does the ground. I find it easiest to pull out all the pieces that go with the area you want to work on and lay them out facing you to see what matches.
After the big parts of the puzzle are completed the smaller things will begin to fall into place and before you know it the puzzle will be finished!
Toys Logo
Hood latch on 2005 Hyundai Sonata won't release
Have someone push down on the hood over the hood latch area while you pull the release, that may work. Once it is open lube everything up with white Lithium grease also known as "LUBRIPLATE:"
Mar 28, 2017 | 2005 Hyundai Sonata
install battery isolator
if it is just the one battery, put the isolator on the ground wire
if the ground wire is turned off by the isolator , there is no circuit
Apr 16, 2017 | Chevrolet Cars & Trucks
How Do I Operate?
Dear mammaSica,
ngfam1 here for you!
I am happy to be of assistance!
1. Is the machine first plugged in?
2. is the door completely shut? push on it or close it again
3.Did you turn to the cycle you wanted?
4.And push the start knob?
perhaps there is a malfunction NEW OR USED!
Today NEW does not make a difference!
I've seen new out of the box be DEAD!!!!!
I believe you should use service for this particular situation!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF
Aug 26, 2008 | Ariston Technologies AWD 129 NA Washer/...
541 people viewed this tip
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
