Tip & How-To about Wine & Spirits
The best before date on bottled water
Water seems like a commodity that can't go bad, so what is up with the best before dates that companies are printing on their labels? Do they really mean anything?
After some research I have found that there is no rule from the FDA that water bottle companies are required to print a best before date. What these dates indicate is that the best quality of the water will be before this date. You will find that when you put water in a bottle after a few days or a while the water will start to taste a little different.
Some times if the water tastes different after the best before date this is an indicator of the chemicals from the plastic leaching into the water. This causes some health concerns, but the chemicals don't really need a lot of time to leach into the water. You will notice that nothing grows in a sealed water bottle but within 2 weeks of opening it you should drink it or toss it because it can start to grow bacteria or mold.
Wine & Spirits Logo
How can I get my Avery 8876 business card sheets to feed through my printer?
Avery is a fairly good name in the business.Brother on the other hand seems to have ignored the reasons why folks don't buy brothers. It's these little annoying things that bigger company's have spent time and energy on. For one there's usually a lever you push to control how much pressure the two fusing rollers push; hot rollers, for years this perplexed the big guys because there all ready is a pretty small tolerance of melting the toner and not burning the paper; melting the toner(powered plastic) next was the ever annoying OHP overhead projector sheets. this is plastic toner on plastic"paper" nightmare! melt the toner but not the plastic its on.... Well enough of engineering issues, time and perseverance paid off. now comes a sticky label on a waxxy surface that is twice as thick as paper and yet has toner to be fixed on it and dried....Some company's like cannon tried a cold roller that seemed to work at first but when things went bad they really went bad.labels coming off all in the wrong places... Toshiba and Savin Ricoh decided to get with Avery and others and make one side harder to come off than the other; reduce the squeeze pressure and increase the opposite "static cling" voltage. Also the angle it hit the feed section// Bypass feed only/Lt-R. Following the printed directions in the individual label sheet seemed to reduce the issue to a minimum. Understanding all the changes the poor piece has to go go through in an 8second processes is half the battle. hope this helps a smidge~~~SC
Nov 08, 2014 | Office Equipment & Supplies
Why is naked drinks company being sued for? Who is the owner of the company?
PepsiCo paid $9 million to settle the lawsuit, which claimed its Naked juices contain ingredients that are far from natural, like synthetic fibers and genetically modified organisms. The company denied some claims, but said it will stop labeling the juices as \'all natural.\'
Jun 27, 2014 | Naked Juice Coconut Water, 11.2oz., 12...
My Brady LabPal label printer seems to be printing labels that are not very bold and, in fact, the numbers are often only half printed. Do I need to change the ink cartridge within it, or what is the problem?
I have label cartridge in but it doesn't print, just says "insert labels". I have tried many times to take cartridge out, and reinsert, but it won't do anything.
Jul 01, 2010 | Brady LAB PAL Thermal Label Printer
zebra lp 2824 faded printing
Many factors affect print quality: Heat settings, speed setting and label face stock quality and type are a great place to start. How old is your printer? How many labels have been printed through it (there is an odometer that tells your this on the config label). Is the printhead dirty? Use > 90% isopropyl alcohol on a cotton ball or microfiber cloth to gently clean the printhead.
I would start by checking the heat and speed settings in the driver - crank up the darkness and crank down the speed a notch or two at a time until you get the print quality that you are looking for. If all of this fails, you may need a new printhead (not too easy to replace on this model). Printheads are made up of an array of resistors. These can loose their electrical resistance over time and require more energy (controlled by the darkness setting) to get the same results as a new printer. Printheads, like labels and car tires are considered a consumable commodity.
Jan 14, 2010 | Zebra Eltron LP 2824 Thermal Printer
hi, can ls2208 scan a memorex 9840 tape bar code label? Understand that in conform to the Code 39 Barcode Specification. It doesnt seem to work. thank you.
Hello khlai. The quick answer to your question is: Yes. An LS2208 can decode (read) code 39 barcodes. However, since you are reading a barcode on a tape, I would predict that the symbology is actually 'Trioptic Code 39". Trioptic Code 39 is a variant of standard Code 39 that is used for marking computer/tape cartridges. I've uploaded the LS2208 manual to my company's website for you. Just follow these instructions and you'll be right as rain.
  1. Go to www.shiftintoblue.com/resources/ls2208_manual.pdf and save the manual to your computer (or print directly from the web.)
  2. Go to and print page 194 (12-28) that contains the Trioptic Code 39 barcodes.
  3. Take the printed page and scan the barcode labeled "Enable Trioptic Code 39".
Then you're all done! That should fix the problem. If you have any other problems, feel free to send me a message or email me. I hope this helps. Good luck!
Jan 05, 2010 | Symbol LS2208 Handheld
653 people viewed this tip
Top Wine & Spirits Experts
deton8 von Splosion
Bill Boyd
Dave braun
Dave braun
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
