Test the high voltage capacitor,
the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed
discharge before testing, or you risk to get electrocuted, even if
power is off. Capacitors can get discharged by shorting their two
contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand
capacitors can be tested. The capacitor must bealloweddischargebefore
testing, or you risk to get electrocuted, evenifpower is off.Capacitors
can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
You can also order from MicrowaveSvc , they also provide parts.
If it is working but not heating, then test the high voltage
test the control board.If turntable is not running check also the door
switch.
The diodeand
capacitors can be tested. The capacitor must be allowed discharge before
testing, or you risk to get electrocuted, evenif power is off.Capacitors
can get discharged by shorting their two contacts.
