Tip & How-To about Crafts & Hobbies
Painting patterns using stencils
Painting a pattern on your wall can be very difficult if you want all the shapes to be the same size and level. But just like when you were little and had letter or shape stencils to help you draw perfect drawings, you can make stencils yourself for what ever it is that you want to paint on the wall.
Using a sheet of cardboard or a contact sheet draw and cut out the shape that you want to paint. If you want to make a pattern that goes all the way around the room then you should make two or three stencils so you can level them.
To use the stencils first prepare the wall you want to paint, you want to paint the base color before you use the stencil because painting around your design can be very challenging. When the wall is dry take your stencil and using painters tape, tape the stencil to the wall so it doesn't move. Making sure that you don't over load the paintbrush paint inside the stencil trying to be careful around the edges. When you finish filling the stencil carefully lift it off, make sure that there isn't any paint on the underside of the stencil because if there is and its wet it will leave unwanted marks on the wall.
Repeat the process of taping, painting and lifting until you have finished painting your pattern on the wall. When you are finished step back and enjoy your handiwork.
Crafts & Hobbies Logo
What kind of painting would I like to have on the wall?
Most of the people love paintings but it is not easy to buy paintings because most of them are very expensive, more than you can imagine. So in such a case, you can choose to have replica painting wall posters. It is not difficult to buy such kind of replica paintings. You will find lots and lots of them. Most of the times, you will end up buying a replica painting that would be more beautiful than the original one. What I personally like about these paintings is that these are very cheap. You can paste them anywhere.
Sep 23, 2015 | Canon PosterArtist 2008
How I match an old pattern of decorative wallpaper hung circa 1990's? Is there a company that can ID old wallpaper from a photo?
wall paper patterns change with the fashion and times
it is unlikely that you would get the pattern off the net as the pattern would be continually updated
I would try face to face with wall paper/ decorator shops with a good photo of the pattern as they may still have the pattern books somewhere in storage
Jun 27, 2015 | Tools & Hardware - Others
Where did spray guns evolved from?
Spray guns evolved from airbrushes, and the two are usually distinguished by their size and the size of the spray pattern they produce.
Feb 03, 2013 | Crafts & Hobbies
What type of painting brush do I need?
If you willing to make painting more professional you need to get different paintbrushes in all shapes and sizes in order to be able to create a good and detailed painting. Small, medium and large brushes are a necessity.
Jan 10, 2013 | Crafts & Hobbies
Masonry Jointer Usage
While the final effects of a stone or concrete wall are stunning, the work to make it beautiful is time-consuming and difficult. Tools are very important in masonry work. Having the right tools for a certain job make all the difference. Jointers come in many different sizes and shapes. Learn the various types and how to use them and you can make quick work of a difficult task. Use an e-jointer for narrower spaces between the stones. There is no handle on the e-jointer, making it easier to smooth and shape the joints between the stones. Whenever your hand is closer to the surface, you can exert more control. Get a bead jointer for raised masonry bricks. These jointers come in two sizes, 1/4-inch by 5/16-inch and 3/8-inch by 1/2-inch. They are small, strong, simple tools that can chip off the excess of a joint that is sticking up off the brink. You do not want to make a deep joint between raised bricks. Change your joint tool to a brick masonry mortar joint raker tool if you are making your project from rougher materials, such as adobe brick or split stone. This tool has many more grooves, which will fit in various sized joints. Turn it on the end for narrow joints and use the curved notch for more intricate patterns between the stones. Switch to a grapevine mortar jointer for very clean lines between the bricks. This tool is used primarily for a colonial look, which is even and measured. Your can get this jointer with a wooden handle for a more even grip.
Aug 27, 2008 | Delta Machinery Delta 37-658 Jointer...
487 people viewed this tip
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
