Tip & How-To about Washing Machines
Eliminate washer Odor
To clean washer add 1 cup of bleach while washer is being filled with hot water and run entire small cycle. DO NOT add clothes. This will help to eliminate odors and any stuck on dirt/ grime on the sides of the drum before washing clothes. I'm not an expert, just an experienced clothes washer for over 30 yrs. ,
Washing Machines Logo
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
how do i remove black mold on gasket
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Frigidaire ATF6000ES Front Load Washer
mold smell comming from duet washer
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We've owned this washing machine for r+ years and it has been making our clothes smell awful--in fact, the machine itself smells awful. I've tried cleaning the basin with a bleach solution and I even ran a load of whites with some bleach to get it in the basin holes--the odor is still offensive. Since this machine uses a sensor to fill the basin, I can't get this washing machine basin clean. What can I do?
By my experience on Washer Machines, I would say that the problem are bacteria and mildew growing in the machine, not exactly in the drain or drum from the machine. Mildew can grow everywhere.
Oh, by the way, don't even think about bypassing any sensor from your machine. You don't want to wake up tomorrow and find a pool in your house, right?
To kill mildew and bacteria you may want to try some simple solutions:
* Keep the lid up between washes so that bacteria and mildew won't grow in it. Pour a bottle of vinegar in hot water and run it though the machine on a heavy load wash. When it is finished, leave the lid up.
* Didn't help? then pour a box of baking soda in it and running it with hot water cycle. Try running it without clothes.
... I mean, Run the washer machine without clothes inside. (Oh my gosh, I should go to bed, it's too late for giving advice on FixYa)
* If the smell continues Pour a big bottle of peroxide hydrogen (the 3% one from the drug store) and run a heavy load wash. Be sure not to use good clothes, it will get white. if that does not work, u may have a more serious problem. Perhaps the machine needs to receive maintenance and spray some peroxide hydrogen where the mildew is growing.
Also, You can try a commercial product for this kind of issue: http://www.smellywasher.com/
Some people says that it works when everything else fails.
Nov 08, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
he4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
1,789 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
