Tip & How-To about Cooktops
How to keep your cutting boards from warping
To keep a cutting board in good condition never rub it with vegetable oil as it will eventually go rancid. Most cutting board conditioners seem to be top secret as they will not divulge what they have in it. Upon researching the internet i discovered that you could use paraffin or a food grade mineral oil. Mineral oil although a byproduct of gasoline manufacture is not toxic as almost all other petroleum products are. Brake fluid and transmission fluids are based off of mineral oil... but it is fine orally used for medical purposes as well. Cutting boards need to be turned over periodically and oiled monthly especially as the weather turns to wet weather... or as it goes back to cold dry air.
Cooktops Logo
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
my baumatic hob keeps sparking for no reason! i was cleaning it and now they keep sparking and i dont know what to do! also, is it dangerous, will gas be leaking?
No. You have some moisture around your igniters. They will stop eventually or you can use a hair dryer to help them along.
Jan 31, 2010 | Baumatic 23 in. BT62 Gas Cooktop
The gas keeps cutting out of my SRV532X. Fuel is LPG Can you help
You probably have a bad gas regulator. Have a service repair technician replace it. Good luck!
Nov 07, 2009 | Smeg 20 in. SRV532X Gas Cooktop
Cillit bang damage to stainless steel hob
I left cillit bang on my Whirlpool stainless steel hob. It left a real mess and looked ruined, however I have a solution. You need Astonish cream cleaner, I got mine from the Kleeneasy catalogue, just get a damp cloth and rub gently all over. You might need to do it a few times, wipe it clean with kitchen roll then rub some oil (I used olive but baby oil is good) and it should buff up to a really good finish.
Mar 19, 2009 | Cooktops
Regular spill stain problems
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 13, 2007 | Maytag MEC5430 Electric Cooktop
881 people viewed this tip
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
