Tip & How-To about Microsoft Office Standard for PC
Calculating weighted averages in Excel
Excel does not have a built in function for calculating a weighted average. For a detailed example of how to do it, follow this link: http:\\www.meadinkent.co.uk\xlwtdavg.htm
Chris
Microsoft Office Standard for PC Logo
what is the "&" symbol for in excel 2010?
The "&" symbol is commonly known as "ampersand" and it is a calculation operator. Ampersand can be used in Excel 2010 to join text items from different cells. It functions much similar as "CONCATENATE" function. The output value you will get by using ampersand function will be the same as the one you will get by using CONCATENATE function. For example, =A1 & B1 returns the same value as=CONCATENATE(A1, B1)
To know more about the CONCATENATE/ ampersand function, you can refer to the following webpages:
http://office.microsoft.com/en-in/excel-help/concatenate-function-HP010342288.aspx
(Important: Below mentioned link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.)
http://excelsemipro.com/2010/08/concatenate-function-or-ampersand-operator-in-excel/
(Important: Below mentioned link applies to Excel 2007. Still, you can refer it to understand more about ampersand function.)
http://office.microsoft.com/en-in/excel-help/combine-the-contents-of-multiple-cells-HA010248390.aspx?CTT=1
GuruAid.com
Jul 30, 2014 | Microsoft Excel 2010
what are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
how do you calculate the cubed root of a number or 5th root of a number?
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
Mar 02, 2011 | Texas Instruments TI-83 Plus Calculator
what is the function of Microsoft excel?
Ok - if your question is "What is Excel" - then the answer is that it is a spreadsheet program that allows you the ability to compute data (usually numbers) for example, pulling together a list of hours worked by employees and adding them up automatically. It also can be used to develop sophisticated computational models and I have used it to develop professional services proposal sizing tools using formulas and functions ... which is a good segwey into my other answer.
If your question is "what is a function or formula in Excel" - then the answer is a function or formula in Excel is a collection of mathematical, text, statistical, etc. preprogrammed tools that allows you to manipulate the data you have in your spreadsheet e.g. a SUM() function that adds a series of numbers, and AVERAGE() funtion that computes the average of a series of numbers, etc.
Hope that helps!
Rgds
David
Oct 01, 2010 | Microsoft Office Excel 2007 Upgrade:...
Need Help Solving Exponential Functions ASAP!!!!
You can calculate =4^1.2 in Excel and get 5.278031643
And also in Excel you can determine what the square root of 2 is (2.506628274631) and then in Excel = 5 ^ 2.506628274631 = 56.5012395907155.
I know this is late but maybe it will help later. Assuming I am doing it right. Thanks!
Mar 29, 2009 | Texas Instruments TI-30XA Calculator
744 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
