Tip & How-To about Home
Mortar and Pestle to make Pesto
Many have chosen to be lazy and try to make pesto with a food processor. However it is widely known that the best way to make pesto is by using a mortar and pestle.
Here is an Italian recipe for the traditional Pesto Genovese:
Ingredients:
2 cloves of garlic
a pinch of kosher salt
100 ml of extravergin olive oil
50 gr of basil leaves
30 gr of grated pecorino cheese
1 tbs of pine nuts
70 gr of grated parmesan
Instructions:
First of all basil leaves should not be washed, rather cleaned with a soft cloth.
Take the peeled garlic cloves and put them in the mortar with a bit of kosher salt. Start grinding.
When the garlic will look creamy add the basil leaves with a pinch of kosher salt and grind.
The grinding should be done towards the walls of the mortar, turning the pestle right and left and the mortar the opposite way.
Continue until the leaves will release a bright liquid, then add the pine nuts and keep grinding.
Add the cheeses a bit at a time, mixing all the time.
Last add the oil, slowly, in a thin line, while mixing.
Mix well until all is one cream.
All the grinding and mixing should be done exclusively in a marble mortar and using a wooden pestle. No metal should be involved.
Home Logo
My Braun 4259 food processor lid just broke. ..Is there anybody who wanted to sell an used one ?
I don't feel that FIXYA is your best option to get an offer from someone seeling you sone used item. Actually, this is a Q/A Forum
See here if you can get the broken part:
Braun Food Processors Parts
Braun Food Processor Parts Accessories
Find parts by model number
Or see ebay, if you can get a used one:
Braun Food Processor eBay
Aug 15, 2015 | Braun Food Processors
food processor is leaking oil
There is next to no oil in a food processor. Sure the top bush/bearing is lubricated with oil but gravity does not go up no matter where you are from.
Feb 06, 2014 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Can you use a food processor instead of a garlic press?
Yes you can, why not. I usually use one when I have a lot of garlic because if its just a small amount im too lazy to wash it.
Feb 04, 2013 | Home
haw can i use ?
My food processor is one of my most-used appliances. I just got a new Cuisinart (at Costco - with an extra workbowl!) and use it at least twice a week. I grate cheeses like cheddar or swiss, pulverize parmesan, make bread crumbs, hummus, pesto, salsa... I make pasta dough in it before rolling out in my Kitchenaid pasta attachment. Pie crusts come together in a flash. And it's great during the holidays for chopping nuts and certain cookie doughs. I've chopped my own beef for burgers, etc, etc. I keep it in a cabinet but it's easy to pull out whenever I need it. And there are only 2 of us at home.
By the way, the blades are so sharp in the new machine that I cut my finger trying to clear something from the blade. I'll use a spatula next time!
ford performance chips.
May 25, 2012 | Food Processors
Grinding nuts
Try chopping the nuts first and remove them. Prepare the rest of the dish and add the nuts, mixing them in at the last.
Mar 18, 2009 | Hamilton Beach 70450 Food Processor
792 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
